ah. mình hiểu rùi. nhưng cho mình hỏi tại sao lại mắc như vậy mà ko phải là vcc----> led---> uln2803---> trở---> VDK
Làm bảng quảng cáo Led
bien_x equ 50h
lap:
mov p1,#10001000b
call tre
mov p1,#01000100b
call tre
mov p1,#00100010b
call tre
mov p1,#00010001b
call tre
mov p1,#10001111b
call tre
mov p1,#01000000b
call tre
mov p1,#00101111b
call tre
mov p1,#00010000b
call tre
mov p1,#10001111b
call tre
mov p1,#01000000b
call tre
mov p1,#00101111b
call tre
mov p1,#00010000b
call tre
mov p1,#10001111b
call tre
mov p1,#01001111b
call tre
mov p1,#00101111b
call tre
mov p1,#00011111b
call tre
mov p1,#10001111b
call tre
mov p1,#01001111b
call tre
mov p1,#00101111b
call tre
mov p1,#00011111b
call tre
mov p1,#00010001b
call tre
mov p1,#00100010b
call tre
mov p1,#01000100b
call tre
mov p1,#10001000b
call tre
mov p1,#00011111b
call tre
mov p1,#00100000b
call tre
mov p1,#01001111b
call tre
mov p1,#10000000b
call tre
mov p1,#00011111b
call tre
mov p1,#00100000b
call tre
mov p1,#01001111b
call tre
mov p1,#10000000b
call tre
mov p1,#00011111b
call tre
mov p1,#00101111b
call tre
mov p1,#01001111b
call tre
mov p1,#10001111b
call tre
mov p1,#00011111b
call tre
mov p1,#00101111b
call tre
mov p1,#01001111b
call tre
mov p1,#10001111b
call tre
mov p1,#00011111b
call tre
mov p1,#00101111b
call tre
mov p1,#01001111b
call tre
mov p1,#10001111b
call tre
jmp lap
TRE:
MOV R5,#3
N3: MOV R6,#200
N2: MOV R7,#200
N1: DJNZ R7,N1
DJNZ R6,N2
DJNZ R5,N3
RET
end
bien_x equ 50h
lap:
mov p0,#11111111b
mov p2,#00111111b
mov p3,#00000100b
call tre
mov p0,#00000111b
mov p2,#00000000b
mov p3,#00001000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#00100000b
call tre
mov p0,#00000000b
mov p2,#00111000b
mov p3,#01000000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#10000000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#01000000b
call tre
mov p0,#00000111b
mov p2,#00000000b
mov p3,#00100000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#00001000b
call tre
mov p0,#00000000b
mov p2,#00111000b
mov p3,#00000100b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#00001000b
call tre
mov p0,#00111000b
mov p2,#00111000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00111111b
mov p3,#00100000b
call tre
mov p0,#11000111b
mov p2,#00111111b
mov p3,#01000000b
call tre
mov p0,#11111000b
mov p2,#00111111b
mov p3,#10000000b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#01000000b
call tre
mov p0,#00000000b
mov p2,#00000000b
mov p3,#00100000b
call tre
mov p0,#00000000b
mov p2,#00111000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#00001000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#00000100b
call tre
mov p0,#00000111b
mov p2,#00000000b
mov p3,#00001100b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#00011100b
call tre
mov p0,#11000111b
mov p2,#00000111b
mov p3,#00111100b
call tre
mov p0,#00111111b
mov p2,#00000000b
mov p3,#01111100b
call tre
mov p0,#00111111b
mov p2,#00111000b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00000111b
mov p3,#00000000b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#10000100b
call tre
mov p0,#11111000b
mov p2,#00000111b
mov p3,#11001100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#00110000b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#01111000b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
jmp lap
TRE:
MOV R5,#3
N3: MOV R6,#200
N2: MOV R7,#200
N1: DJNZ R7,N1
DJNZ R6,N2
DJNZ R5,N3
RET
end
ra đường thấy nhiều biển led quang cáo thấy đẹp mắt ...cố gắng làm 1 cái cho bằng anh bằng em mong các bác chỉ giáo em vài chiêu : mình có ra chợ nhật tảo tham khảo và mua dc bộ VDK EPROM 20 kiểu nháy 12v 16 cổng mỗi cổng mác nối tiếp từ 50 đến 70 led . nhưng khi mang về thì mình không bit cách mắc các bóng led và trở như thế nào
mình tính làm cái bảng quang cao có các chữ như sau : sửa chữa ĐTDĐ
các bác cho xin cái sơ đồ câu led nối tiếp ...mình dự tính 1 chữ mình mác khoang 14 led
p/s vì là dân ngoại đạo lên kiến thức điện tử của mình chỉ bàng hạt gạo
Nguyên văn bởi xuanohyes89 Xem bài viếtMình làm thế này các bạn xem thử đùng ko nhé
Và xem giúp mình con trở phân cực cho chân B đó dùng bao nhiêu là vừa???
Thân
Link down:
LUONG Y VU NGOC KET.pdf
Nguyên văn bởi vucongquantb Xem bài viếtBạn tham khảo sơ đồ mình làm nè. Mạch cho ra 16 cổng, xuất ra trên P1 và P3. Tầng kéo dòng cho Led dùng TIP41C và 74HC245. Nguồn 12VDC, 15A cấp cho LED, nguồn 5VDC cấp cho AT89C51.
Link down:
Boar bạn thiết kế sao ko thiết kế 32 cổng luôn, lúc đó mình muốn xài bao nhiêu thì xài. ( Góp ý đừng la)
Mình có cái mạch này chuyên bán cho bọn quảng cáo. Chưa cài PDF xuất ảnh này tạm. Có mạch in PT nè.89xx.rarPCCC
Nguyên văn bởi lep140389 Xem bài viếtBạn cấp tải j mà tới 15A thế bạn, Led công suất ah.
Mà làm như bạn mình nghĩ không được hay cho lắm, phải chăng khi muốn mạch hoạt động bạn phải làm thao tác cấp nguồn 2 lần(1 cho bo điều khiển 8051, 1 cho mạch hiển thị là bảng LED?) tại sao bạn không gộp cả 2 lại là 1, toàn mạch(khối nguồn, khối công suất, khối điều khiển) nằm trên 1 board luôn, đỡ phải chia ra làm nhiều board con.Last edited by vucongquantb; 02-01-2012, 14:18.
Link down:
LUONG Y VU NGOC KET.pdfĐT: 0972 20 58 68
Gmail:
Nguyên văn bởi vucongquantb Xem bài viếtừh, mình làm bảng quảng cáo lớn. Có một số người dùng hẳn nguồn máy tính, dùng như vậy phí quá, mà làm như mình tính ổn định cũng cao mà, dong ra cũng đâu thua kém gì. Mạch của bạn không có nút reset àh, làm như vậy thì không được hay cho lắm. Chẳng lẽ khi muốn reset lại rút nguồn cấp chính cho mạch ra rồi lại cắm lại?
Còn phần reset thì bạn đừng quan tâm làm j, mình cố ý làm vậy.PCCC
Nguyên văn bởi [VN]NMD Xem bài viếtBạn cho mình hỏi, có phải bạn dùng Tip41 k. Cho mình xin tên linh kiện luôn nha. Mình thấy 1 số bạn trên diễn đàn dùng thêm con 595 nữa, nhưng mạch của bạn không thấy ( mình mới vào nghề nên chưa rành) bạn giải thích giùm mình nha . mail mình: lvlyloves@yahoo.com
Nếu 1 cổng của bạn sử dụng chịu đựng đc công suất bao nhiêu thì nên gắn trans hoặc fet có công suất = hoặc lớn hơn.PCCC
Hôm qua, 15:47 -
18-01-2025, 20:47 -
18-01-2025, 20:42 -
18-01-2025, 18:56 -
17-01-2025, 21:36 -
Trả lời cho Giúp em về mạch MPPT và Solar Panel với!?bởi dinhthuong80Vâng, em cũng nghĩ thế khi search được hãng ấy là SRNE, nên em test luôn những cái còn lại, và kết quả đều như nhau.
Nhận thấy kết quả khó chấp nhận, em cũng phân vân có nên mail cho họ để họ thử kiểm tra mã đó không; giữa...-
17-01-2025, 11:33 -
Trả lời cho Giúp em về mạch MPPT và Solar Panel với!?bởi dinhthuong80Xin cảm ơn bác bqviet luônnhiệt tình cho biết nhiều thông tin quí báu, cảm ơn bạn mèomướp có ví dụ đơn giản và dễ hiểu, cảm ơn tất cả đã bớt chút thời gian quí báu vào đây đọc bài.
Cảm ơn bác nhathung1101 cho thông tin và chúc mừng bác mua được những tấm pin NLMT cực tốt theo...-
17-01-2025, 11:22 -
Trả lời cho Giúp em về mạch MPPT và Solar Panel với!?bởi mèomướpDạ chú nhat... cứ coi pin mặt trời như 1 cái ắc qui nhìu ngăn mắc nối tiếp ấy ạ. Khi 1 ngăn yếu thì cả cái ắc qui yếu luôn ạ. Nó có nhìu bộ nối tiếp mắc song song nên bị che 1 khoảng nhỏ ảnh hưởng nhìu nhưng chắc ko đến nỗi mất 50% đâu ạ...
17-01-2025, 06:36 -
Trả lời cho Giúp em về mạch MPPT và Solar Panel với!?bởi nhathung1101Nếu nói bị cái lá che sáng mà giảm 50% thì tôi càng không tin, bởi trên vườn tôi mặc kệ ông trời làm vệ sinh.
Tức là lá tự rụng, gió tự dọn. Ai hơi đâu mà leo lên dọn. Nếu phải như thế thì tôi dek thèm lắp làm gì.-
16-01-2025, 21:44 -
