Hỏi Về Bảng Led matrix 8 x 24 của Rixin mua tại nhật tảo
    cho em hỏi cái code của em sao nap vào nó không chạy vậy em cắm 2 công p1 và p3
    em cám ơn trước
    #include "AT89C51.h"
    bdata unsigned char tmp;
    sbit bit0 = tmp^0;
    sbit bit1 = tmp^1;
    sbit bit2 = tmp^2;
    sbit bit3 = tmp^3;
    sbit bit4 = tmp^4;
    bit time0;
    unsigned char dong[52][5];
    unsigned char bangma[130] = {
    0x3F,0x50,0x90,0x50,0x3F,//A
    0xFF,0x99,0x99,0x66,0x00,//B
    0x7E,0x81,0x81,0x81,0x42,//C
    0xFF,0x81,0x81,0x42,0x3C,//D
    0xFF,0x91,0x91,0x91,0x81,//E
    0xFF,0x90,0x90,0x90,0x80,//F
    0x7E,0x81,0x89,0x4F,0x08,//G
    0xFF,0x10,0x10,0x10,0xFF,//H
    0x81,0x81,0xFF,0x81,0x81,//I
    0x87,0x81,0xFF,0x80,0x80,//J
    0xFF,0x28,0x44,0x82,0x01,//K
    0xFF,0x01,0x01,0x01,0x01,//L
    0xFF,0x40,0x20,0x40,0xFF,//M
    0xFF,0x20,0x08,0x02,0xFF,//N
    0x7E,0x81,0x81,0x81,0x7E,//O
    0xFF,0x88,0x88,0x88,0x70,//P
    0x7E,0x81,0x85,0x7E,0x01,//Q
    0xFF,0x98,0x94,0x62,0x01,//R
    0x62,0x91,0x91,0x91,0x4E,//S
    0x80,0x80,0xFF,0x80,0x80,//T
    0xFE,0x01,0x01,0x01,0xFE,//U
    0xF0,0x04,0x01,0x04,0xF0,//V
    0xFE,0x01,0x0E,0x01,0xFE,//W
    0xC3,0x24,0x18,0x24,0xC3,//X
    0x80,0x40,0x3F,0x40,0x80,//Y
    0x87,0x89,0x91,0xA1,0xC1//Z
    unsigned char title[50] = "Chuc mung nam moi";
    void Timer0_ISR(void) interrupt 1
    EA = 0;
    ET0 = 0;
    IE0 = 0;
    time0 = 0;
    TR0=0; //stop time0
    TF0=0;
    return;
    void delay(unsigned char n) /* do nothing n*1ms */
    unsigned char j;
    j=n;
    do
    { EA = 1;
    ET0 = 1;
    IE0 = 1;
    TL0=(65535-921)&0xff; // set time0 = 1ms
    TH0=(65535-921)>>8;
    TR0=1; // start time0
    time0 = 1;
    while (time0){}
    while (--j!=0);
    void trabang(unsigned char vitri,m)
    unsigned char v,n,l;
    v = vitri;
    l = m;
    for (n=0;n<5;n++)
    dong[l][n] = bangma[v+n];
    void dongchuchay(void)
    unsigned char m;
    for (m = 0; m < 50; m++)
    switch (title[m])
    case ('A'): trabang(0,m); break;
    case ('a'): trabang(0,m); break;
    case ('B'): trabang(5,m); break;
    case ('b'): trabang(5,m); break;
    case ('C'): trabang(10,m); break;
    case ('c'): trabang(10,m); break;
    case ('D'): trabang(15,m); break;
    case ('d'): trabang(15,m); break;
    case ('E'): trabang(20,m); break;
    case ('e'): trabang(20,m); break;
    case ('F'): trabang(25,m); break;
    case ('f'): trabang(25,m); break;
    case ('G'): trabang(30,m); break;
    case ('g'): trabang(30,m); break;
    case ('H'): trabang(35,m); break;
    case ('h'): trabang(35,m); break;
    case ('I'): trabang(40,m); break;
    case ('i'): trabang(40,m); break;
    case ('J'): trabang(45,m); break;
    case ('j'): trabang(45,m); break;
    case ('K'): trabang(50,m); break;
    case ('k'): trabang(50,m); break;
    case ('L'): trabang(55,m); break;
    case ('l'): trabang(55,m); break;
    case ('M'): trabang(60,m); break;
    case ('m'): trabang(60,m); break;
    case ('N'): trabang(65,m); break;
    case ('n'): trabang(65,m); break;
    case ('O'): trabang(70,m); break;
    case ('o'): trabang(70,m); break;
    case ('P'): trabang(75,m); break;
    case ('p'): trabang(75,m); break;
    case ('Q'): trabang(80,m); break;
    case ('q'): trabang(80,m); break;
    case ('R'): trabang(85,m); break;
    case ('r'): trabang(85,m); break;
    case ('S'): trabang(90,m); break;
    case ('s'): trabang(90,m); break;
    case ('T'): trabang(95,m); break;
    case ('t'): trabang(95,m); break;
    case ('U'): trabang(100,m); break;
    case ('u'): trabang(100,m); break;
    case ('V'): trabang(105,m); break;
    case ('v'): trabang(105,m); break;
    case ('W'): trabang(110,m); break;
    case ('w'): trabang(110,m); break;
    case ('X'): trabang(115,m); break;
    case ('x'): trabang(115,m); break;
    case ('Y'): trabang(120,m); break;
    case ('y'): trabang(120,m); break;
    case ('Z'): trabang(125,m); break;
    case ('z'): trabang(125,m); break;
    void hiencot(unsigned char ma, unsigned char cot)
    tmp = cot;//+1;
    P1 = 0x00;
    P3_0 = bit0;
    P3_1 = bit1;
    P3_2 = bit2;
    P3_3 = bit3;
    P3_4 = bit4;
    P1 = ma;
    void main()
    { unsigned char i,j,k;
    dongchuchay();
    while (1)
    for (i=0;i<24;i++)
    for (k=0;k<40;k++) //Tre 1s
    for (j=0;j<=i;j++)
    hiencot(dong[0][j],23-i+j);
    delay(1); // Tre 1ms
    for (i=0;i<100;i++)
    for (j=0;j<24;j++)
    hiencot(dong[0][24-j+i],23-j);
      Nguyên văn bởi chung25t1cnt Xem bài viết
      cho mình hỏi phần lập trình cơ bản như thế nào
      bạn ơi có thể cho mình xem phần bo mạch bên vi điều khiển của bạn đc ko? cám ơn bạn trước mình cũng đang làm cái này mà còn gà lắm
        có ai giúp mình không
          buồn quá trời ai giúp dùm mình đi
          chung25t1cnt Tìm hiểu thêm về chung25t1cnt
