đo dòng 1 chiều sử dụng 8051
  • đo dòng 1 chiều sử dụng 8051
    đây là code của thằng bạn nó gửi cho em, nhưng không có hình
    #include<reg52.h>
    #include<stdio.h>
    #include<math.h>
    //khai bao cac bit
    sbit adc_int=P2^5;
    sbit adc_rd=P2^3;
    sbit adc_rw=P2^4;
    sbit led1=P2^0;
    sbit led2=P2^1;
    sbit led3=P2^2;
    sbit thang1=P1^7;
    sbit thang2=P1^6;
    sbit thang3=P1^5;
    float volt,ampe;
    unsigned char chuc,donvi,phan1,phan2,nguyen,phan;
    unsigned int x;
    unsigned char M[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x02,0x82,0xF8,0x80,0x9 0}; //array use dp
    unsigned char M1[10]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x1 0}; //arrray use dp
    void delay(delay) //delay use timer 0 mode 2
    TMOD=0x02;
    TH0=TL0=-100;
    TR0=1;
    while(!TF0);
    TF0=0;
    TR0=0;
    void dieukhien_adc(void)//control adc
    adc_rw=0;
    delay(2);
    adc_rw=1;
    while(adc_int);
    adc_rd=0;
    x=P3;
    adc_rd=1;
    void hienthi(void)//scan led
    unsigned int i;
    ampe=ampe*10;
    ampe=(int)(ampe);
    nguyen=ampe/10;
    phan=(int)(ampe)%10;
    phan1=phan/10;
    phan2=phan%10;
    if((nguyen==0)&&(phan1<=1))
    donvi=nguyen;
    phan1=phan/10;
    phan2=phan%10;
    for(i=0;i<100;i++)
    led3=1;
    led1=0;
    led2=0;
    P0=0x40;
    delay(100);
    led2=1;
    led1=0;
    led3=0;
    P0=M[phan1];
    delay(100);
    led1=1;
    led2=0;
    led3=0;
    P0=M[phan2];
    delay(100);
    if((nguyen<1)&&(phan1>1))
    donvi=nguyen;
    phan1=phan/10;
    phan2=phan%10;
    for(i=0;i<100;++i)
    led3=1;
    led1=0;
    led2=0;
    P0=M1[donvi];
    delay(100);
    led2=1;
    led1=0;
    led3=0;
    P0=M[phan1];
    delay(100);
    led1=1;
    led2=0;
    led3=0;
    P0=M[phan2];
    delay(100);
    if((nguyen<=10)&&(nguyen>=1))
    donvi=nguyen/10;
    phan1=phan/10;
    phan2=phan%10;
    for(i=0;i<100;++i)
    led3=1;
    led2=0;
    led1=0;
    P0=M1[nguyen];
    delay(100);
    led2=1;
    led1=0;
    led3=0;
    P0=M[phan1];
    delay(100);
    led1=1;
    led2=0;
    led3=0;
    P0=M[phan2];
    void tatled(void) //off led
    led1=0;
    led2=0;
    led3=0;
    P0=0xFF;
    void main(void) //main funtion
    while(1)
    while(thang1==0)
    dieukhien_adc();
    volt=(float)(x*100)/255; //range from 0 to 10
    while(thang2==0)
    dieukhien_adc();
    volt=(float)(x*10)/255; //range from 0 to 1
    while(thang3==0)
    dieukhien_adc();
    volt=(float)(x*1)/255; //range from 0 to 0.1
    ampe=volt/10;
    hienthi();
    hicc , đề bài của em là : đo dòng 1 chiều sử dụng 8051 hiển thị lên led 7 thanh. Ai giúp em với
    ai giúp em với
      Giúp cho bạn như mò kim đáy bể, cung cấp thêm thông tin về đề tài đi bạn.
      Quan trọng nhất là phải có sơ đồ nguyên lý thì mới giúp đc.
        đây là cái hình ảnh thằng bạn nó gửi cho em để tham khảo. Bác xem giúp em nhé
        yêu cầu là : đo dòng 1 chiều sử dụng 8051 hiển thị ra led 7 thanh
          Để đo dòng, phương pháp chính là chuyển đo dòng sang đo áp.
          Nếu dòng lớn, có thể dùng điện trở tùy loại như 0.1 ohm hay 1ohm. Rồi dùng opam khuyếch đại lên, qua ADC là xong!
            ơ, nhưng mà tóm lại là giúp cái gì nhẩy................................
              dạ em cần bản vẽ chính xác và phần lập trình ạ. Thú thực là em hơi dốt về mảng này, vì bọn em học đa hệ nhưng em chỉ đi sâu về điện chiếu sáng vì sau này ra làm cùng anh em bên xây dựng thôi ạ. Đây là bài tập lớn của em
                help meeee
                  các pác giúp em với ạ. sao ko co ai thế. hixxx
                    Ko làm được thì đi thuê. Chứ có cơm, có thịt , ai rỗi hơi đi đút thìa vào tận mồm cho nữa ?!
                      Phương pháp rẻ tiền nhất có lẽ là dùng điện trở shun để lấy áp theo định luật om U= I.R.
                      Sau đó bạn cho qua mạch khuyếch đại thuật toán==> Mạch lọc thông thấp==>hạn biên==>cho vào ADC==>Hiển thị
                      Bạn có thể tham khảo những đề tài sử dụng đến adc như: đo nhiệt độ...(trong diễn đàn đã có rồi đấy) các anh ấy hướng dẫn chi tiết lắm
                      Phương pháp khác là dùng cảm biến hall, nhưng khá đắt tiền...không phù hợp với SV
                      Quang Nhat
                      Yahoo :quangnhat85ls
                      Mail :
                        Nguyên văn bởi ssgabeo Xem bài viết
                        Bác chỉ cho em chỗ thuê với. Nếu bác làm thì cho em cái giá giúp em với. Thú thực với bác là em học nghành điện, bọn em học tất tần tật từ điện chiếu sáng, điện dân dụng, công nghiệp....( cái mà bọn em học 3-5 trình = người ta học 4-5 năm ).Nói chung là cưỡi ngựa xem hoa, chỉ ra để lấy cái bằng. Em thì chỉ đi chuyên sâu về các mảng thiết kế điện công trình ( vì nhà em có người nhận ). Nên thú thực là em chịu. Đây là bài tập trong phần đồ án của em, bắt buộc phải làm ạ
                        trungtin1232 Tìm hiểu thêm về trungtin1232
