Nguyên văn bởi hoangphat
để góp bài với mục đích giúp đỡ như chủ topic HoangPhat góp 3 bài dùng led 7 seg
mạch đồng hồ đơn giản dùng 89sxx
đây là code
chúc các pác công thành
đây là code
Code:
;************************************************* ** ;CHUONG TRINH DIEU KHIEN HIEN THI DEM GIO - PHUT - GIAY ;(LED1,2 DEM GIAY, LED3,4 DEM PHUT, LED5,6 DEM GIO) ;************************************************* ** ;CAC DOAN (A-G) -> PORT0. CHON LED 7 DOAN (8 LED) -> PORT1 ;NUT MODE -> P3.0, UP -> P3.1, DOWN -> P3.2 ;************************************************* ** GIAY EQU R2 PHUT EQU R3 GIO EQU R4 B_GIAY EQU R7 B_MODE EQU R6 MODE BIT P3.0 UP BIT P3.1 D0WN BIT P3.2 ORG 000H LJMP MAIN ORG 00BH LJMP ISR_T0 MAIN: MOV TMOD,#01H ;CHE DO TIMER - MODE 1 MOV TH0,#3CH ;THOI GIAN TIMER - 50MS MOV TL0,#0B0H CLR TF0 ;XOA CO TRAN SETB TR0 ;CHAY TIMER MOV IE,#82H ;CHO PHEP NGAT TIMER0 MOV B_MODE,#0 TD: MOV GIO,#0 ;NAP GIA TRI GIO BAN DAU X4: MOV PHUT,#0 ;NAP GIA TRI PHUT BAN DAU X3: MOV GIAY,#0 ;NAP GIA TRI GIAY BAN DAU MOV B_MODE,#0 X2: MOV B_GIAY,#0 ;NAP GIA TRI BAN DAU CHO BIEN DEM SO LAN NGAT TIMER LCALL HEX_BCD ;DOI GIA TRI THOI GIAN -> BCD -> MA 7 DOAN LCALL BCD_7DOAN X1: LCALL HIENTHI ;HIEN THI THOI GIAN JNB MODE,ADJ ;KIEM TRA NUT MODE - DUNG -> PHAN CHINH THOI GIAN ADJ CJNE B_GIAY,#20,X1 ;KIEM TRA SO LAN NGAT TIMER - 20 LAN x 50MS = 1S INC GIAY ;TANG GIAY CJNE GIAY,#60,X2 ;SO SANH DU 60 GIAY - CHUA DU -> QUAY LAI HIEN THI INC PHUT ;TANG PHUT CJNE PHUT,#60,X3 ;SO SANH DU 60 PHUT - CHUA DU -> QUAY LAI HIEN THI INC GIO ;TANG GIO CJNE GIO,#24,X4 ;SO SANH DU 60 GI0 - CHUA DU -> QUAY LAI HIEN THI SJMP TD ;DU -> QUAY LAI TU DAU ;************************************************* ** ;CHUONG TRINH CON DOI HEX -> BCD (TACH SO HEX) ;************************************************* ** ;R2 -> 11H & 10H, R3 -> 13H & 12H, R4 -> 15H & 14H ;************************************************* ** HEX_BCD: MOV R0,#02 ;NAP DIA CHI DAU CUA VUNG NHO CHUA SO HEX MOV R1,#10H ;NAP DIA CHI DAU CUA VUNG NHO CHUA SO BCD H1: MOV B,#10 ; MOV A,@R0 ;LAY SO HEX CAN CHUYEN DOI DIV AB ;CHIA 10 DE TACH RIENG BYTE THAP VA BYTE CAO MOV @R1,B ;CAT BYTE THAP INC R1 ;TANG DIA CHI VUNG NHO CHUA SO BCD MOV @R1,A ;CAT BYTE CAO INC R0 ;TANG DIA CHI VUNG NHO CHUA SO HEX INC R1 ;TANG DIA CHI VUNG NHO CHUA SO BCD CJNE R0,#05H,H1 ;KIEM TRA HOAN TAT VIEC CHUYEN DOI RET ;************************************************* ** ;CHUONG TRINH CON DOI SO BCD -> MA 7 DOAN ;************************************************* ** ;SO BCD (10H - 15H) -> MA 7 DOAN (20H - 25H) ;************************************************* ** BCD_7DOAN: MOV DPTR,#200H ;NAP DIA CHI VUNG CHUA MA 7 DOAN MOV R0,#10H ;NAP DIA CHI DAU TIEN CUA VUNG NHO CHUA SO BCD MOV R1,#20H ;NAP DIA CHI DAU TIEN CUA VUNG NHO CHUA MA 7 DOAN B1: MOV A,@R0 ;GIAI MA MOVC A,@A+DPTR MOV @R1,A INC R0 ;TANG DIA CHI VUNG NHO CHUA SO BCD INC R1 ;TANG DIA CHI VUNG NHO CHAU MA 7 DOAN CJNE R0,#16H,B1 ;KEM TRA HOAN TAT VIEC GIAI MA RET ;************************************************* ** ;CHUONG TRINH CON HIEN THI (20H - 25H) ;************************************************* ** HIENTHI: MOV R0,#20H ;DIA CHI DAU TIEN CUA VUNG CHUA DU LIEU CAN HIEN THI MOV A,#0FEH ;MA QUET DAU TIEN HT1: MOV P0,@R0 ;LAY DU LIEU CAN HIEN THI MOV P1,A ;XUAT MA QUET LCALL DELAY MOV P1,#0FFH ;TAT LED DE CHONG LEM LCALL DELAY INC R0 ;CHUYEN SANG DIA DIA KE TIEP RL A ;THAY DOI MA QUET CJNE A,#0BFH,HT1 ;KIEM TRA QUET XONG CHUA - CHUA XONG -> QUAY VE LAM TIEP RET ;TRO LAI KHI DA QUET VA HIEN THI XONG ;************************************************* ** ISR_T0: ;ISR TIMER0 - 50MS CLR TR0 CLR TF0 MOV TH0,#3CH MOV TL0,#0B0H INC B_GIAY ;TANG BIEN DEM SO LAN NGAT - 1 LAN = 50MS SETB TR0 RETI ;************************************************* ** ADJ: ;CHUONG TRINH CON XU LY NUT MODE LCALL HIENTHI JNB MODE,ADJ ;KIEM TRA NHU MODE DA DUOC THA RA HAY CHUA INC B_MODE ;TANG SO LAN NHAN NUT MODE CJNE B_MODE,#4,ADJ_GPG ;KIEM TRA SO LAN NHAT NUT MODE MOV B_MODE,#0 ;DU 3 LAN -> TRO LAI TU DAU MOV B_GIAY,#0 SJMP X2 ;************************************************* ** ADJ_GPG: LOOP1: MOV 76H,#10 ;SO LAN CHOP TAT CAP LED DANG DUOC CHINH LOOP2: MOV 77H,#0FFH ;SO LAN KIEM TRA NUT NHAN LCALL HEX_BCD LCALL BCD_7DOAN LOOP: LCALL HIENTHI CJNE B_GIAY,#20,Z1 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NUT NHAN LJMP TANGGIAY ;DU 20 LAN NGAT -> TANG GIAY Z1: JNB UP,TANG ;KIEM TRA NUT UP JNB D0WN,GIAM ;KIEM TRA NUT DOWN JNB MODE,ADJ ;KIEM TRA NUT MODE DJNZ 77H,LOOP ;GIAM SO LAN KIEM TRA NUT NHAN MOV 77H,#0FFH ;NAP SO LAN TAT (THOI GIAN TAT) CJNE B_MODE,#1,SS11 ;KIEM TRA NHAN MODE 1 LAN - SAI -> KIEM TRA TIEP SS11 MOV 24H,#0FFH ;DUNG - NHAN MODE 1 LAN -> NAP GIA TRI TAT LED... MOV 25H,#0FFH ;CHO PHAN "GIO" SJMP TAT ;HIEN THI TRANG THAI LED SS11: CJNE B_MODE,#2,SS12 ;KIEM TRA NHAN MODE 2 LAN - SAI -> KIEM TRA TIEP SS12 MOV 22H,#0FFH ;DUNG - NHAN MODE 2 LAN -> NAP GIA TRI TAT LED... MOV 23H,#0FFH ;CHO PHAN "PHUT" SJMP TAT ;HIEN THI TRANG THAI LED SS12: ;NHAN MODE 3 LAN -> NAP GIA TRI TAT LED... MOV 20H,#0FFH ;CHO PHAN "GIAY" MOV 21H,#0FFH TAT: LCALL HIENTHI ;HIEN THI CJNE B_GIAY,#20,Z2 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NUT NHAN LJMP TANGGIAY ;DU 20 LAN NGAT -> TANG GIAY Z2: JNB UP,TANG ;KIEM TRA NUT UP JNB D0WN,GIAM ;KIEM TRA NUT DOWN JNB MODE,ADJ ;KIEM TRA NUT MODE DJNZ 77H,TAT ;GIAM SO LAN TAT (THOI GIAN TAT) DJNZ 76H,LOOP2 ;GIAM SO LAN CHOP TAT CAP LED MOV B_MODE,#0 ;XOA SO LAN NHAN NUT MODE LJMP X2 ;QUAY LAI TANG: LCALL HIENTHI CJNE B_GIAY,#20,Z3 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NHU NHAN LJMP TANGGIAY ;DU 20 LAN NGAT -> TANG GIAY Z3: JNB UP,TANG CJNE B_MODE,#1,SS1 INC GIO CJNE GIO,#24,LOOP1 MOV GIO,#0 LOOP11: LJMP LOOP1 SS1: CJNE B_MODE,#2,SS2 INC PHUT CJNE PHUT,#60,LOOP1 MOV PHUT,#0 SJMP LOOP1 SS2: INC GIAY CJNE GIAY,#60,Z5 MOV GIAY,#0 Z5: LJMP LOOP1 GIAM: LCALL HIENTHI CJNE B_GIAY,#20,Z4 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NUT NHAN LJMP TANGGIAY ;DU 20 LAN NGAT -> TANG GIAY Z4: JNB D0WN,GIAM CJNE B_MODE,#01,SS3 DEC GIO CJNE GIO,#0FFH,K1 MOV GIO,#23 K1: LJMP LOOP1 SS3: CJNE B_MODE,#02,SS4 DEC PHUT CJNE PHUT,#0FFH,K2 MOV PHUT,#59 K2: LJMP LOOP1 SS4: DEC GIAY CJNE GIAY,#0FFH,K3 MOV GIAY,#59 K3: LJMP LOOP1 ;************************************************* ** TANGGIAY: MOV B_GIAY,#0 INC GIAY CJNE GIAY,#60,EXIT MOV GIAY,#0 INC PHUT CJNE PHUT,#60,EXIT MOV PHUT,#0 EXIT: LJMP LOOP ;************************************************* ** DELAY: ;CHUONG TRINH CON TAO THOI GIAN TRE 150US MOV 7FH,#50H DJNZ 7FH,$ RET ;************************************************* ** ORG 200H ;VUNG MA 7 DOAN DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H END
