mình nữa annhandt09@gmail.com
Mạch sao băng dung 89cxx
This topic is closed.
wood
Nguyên văn bởi trungdt_1991 Xem bài viếtMình vừa làm xong mạch sao băng dùng 89c52 , bạn nào muốn làm thì đưa địa chỉ email
lên mình gửi cho.
minh thay chay qua chay lai rat dep ma.
#include <REGX51.H>
unsigned char led[16]={255,250,150,90,30,15,12,8,6,4,4,1,1,0,0,0};
void delay_ms(unsigned int mmmmmsssss,tttttaaaaa){
//65535ms 9000MHz
while(mmmmmsssss--){
unsigned int xxxxxxxxxx = 7*tttttaaaaa+1;
while(xxxxxxxxxx--);
/*xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx*/
/*void delay(unsigned long t)
unsigned int m;
for(m=0;m<t;m++);
unsigned char dem=0,nho;
/*xxxxxxxxxxxxxxx*/
void Timer0()interrupt 1 {
TF0=0; TR0=0;
//if(dem==0) {P0=0;P2=0;}
if(dem>=led[0]) P0_0=0; else P0_0=1;
if(dem>=led[1]) P0_1=0; else P0_1=1;
if(dem>=led[2]) P0_2=0; else P0_2=1;
if(dem>=led[3]) P0_3=0; else P0_3=1;
if(dem>=led[4]) P0_4=0; else P0_4=1;
if(dem>=led[5]) P0_5=0; else P0_5=1;
if(dem>=led[6]) P0_6=0; else P0_6=1;
if(dem>=led[7]) P0_7=0; else P0_7=1;
if(dem>=led[8]) P2_7=0; else P2_7=1;
if(dem>=led[9]) P2_6=0; else P2_6=1;
if(dem>=led[10]) P2_5=0; else P2_5=1;
if(dem>=led[11]) P2_4=0; else P2_4=1;
if(dem>=led[12]) P2_3=0; else P2_3=1;
if(dem>=led[13]) P2_2=0; else P2_2=1;
if(dem>=led[14]) P2_1=0; else P2_1=1;
if(dem>=led[15]) P2_0=0; else P2_0=1;
dem++;
TR0=1;
/*xxxxxxxxxxxxxxx*/
/*void Timer1()interrupt 3 {
TF1=0; TR1=0;
if(dem>=led[15]) P0_0=0; else P0_0=1;
if(dem>=led[14]) P0_1=0; else P0_1=1;
if(dem>=led[13]) P0_2=0; else P0_2=1;
if(dem>=led[12]) P0_3=0; else P0_3=1;
if(dem>=led[11]) P0_4=0; else P0_4=1;
if(dem>=led[10]) P0_5=0; else P0_5=1;
if(dem>=led[9]) P0_6=0; else P0_6=1;
if(dem>=led[8]) P0_7=0; else P0_7=1;
if(dem>=led[7]) P2_7=0; else P2_7=1;
if(dem>=led[6]) P2_6=0; else P2_6=1;
if(dem>=led[5]) P2_5=0; else P2_5=1;
if(dem>=led[4]) P2_4=0; else P2_4=1;
if(dem>=led[3]) P2_3=0; else P2_3=1;
if(dem>=led[2]) P2_2=0; else P2_2=1;
if(dem>=led[1]) P2_1=0; else P2_1=1;
if(dem>=led[0]) P2_0=0; else P2_0=1;
dem++;
TR1=1;
/*xxxxxxxxxxxxxxxxxxxxx quay phai xxxxxxxxxxxxxxxxxxxxx*/
void main(void)
while(1)
unsigned int i,j,k;
TH0=180;
TL0=180;
TMOD=0x02; //timer 0: che do 2: 8 bit tu dong nap lai
EA=1; ET0=1; TR0=1;
for(i=1;i<500;i++)
delay_ms(15,10); dem=0;
nho= led[0];
led[0]= led[1]; led[1]= led[2]; led[2]= led[3]; led[3]= led[4];
led[4]= led[5]; led[5]= led[6]; led[6]= led[7]; led[7]= led[8];
led[8]= led[9]; led[9]= led[10]; led[10]=led[11]; led[11]=led[12];
led[12]=led[13]; led[13]=led[14]; led[14]=led[15]; led[15]=nho;
/*xxxxxxxxxxxxxx quay phai xxxxxxxxxxxxxxxxxxx*/
/*TR0=0;
TH1=180;
TL1=180;
EA=1; ET1=1; TR1=1;*/
for(j=1;j<500;j++)
nho= led[15];
led[15]= led[14]; led[14]= led[13]; led[13]= led[12]; led[12]= led[11];
led[11]= led[10]; led[10]= led[9]; led[9]= led[8]; led[8]= led[7];
led[7]= led[6]; led[6]= led[5]; led[5]=led[4]; led[4]=led[3];
led[3]=led[2]; led[2]=led[1]; led[1]=led[0]; led[0]=nho;
/*xxxxxxx chop tat xxxxxxxxxxxxxxxxxxxxxxx*/
TR0=0;
for(k=1;k<20;k++)
P0_0=0;
P0_1=0;
P0_2=0;
P0_3=0;
P0_4=0;
P0_5=0;
P0_6=0;
P0_7=0;
P2_7=0;
P2_6=0;
P2_5=0;
P2_4=0;
P2_3=0;
P2_2=0;
P2_1=0;
P2_0=0;
delay_ms(60,30);
P0_0=1;
P0_1=1;
P0_2=1;
P0_3=1;
P0_4=1;
P0_5=1;
P0_6=1;
P0_7=1;
P2_7=1;
P2_6=1;
P2_5=1;
P2_4=1;
P2_3=1;
P2_2=1;
P2_1=1;
P2_0=1;
delay_ms(60,30);
89c52
lên mình gửi cho.
:truongvanly.hn@gmail.com
uhm....anh nao biếtlooixx báo nhu vầy thì pm giùm nha....http://seablogs.zenfs.com/u/jpLyoKWc...34.jpg....cái orcad của em khi chuyển từ CAptur sang LAyout là bị như vậy á ai biết thì chỉ em với.......nguyen_thanh_phong_9009@yahoo.com.vn
bởi mèomướpDạ chú nhat... hông nên nói chơi về thần tiên đâu ạ...
hôm nay, 06:22 -
bởi nhathung1101Em ăn chay, thì đã lên chùa.
Em lên chùa thì Bụt chạy mất dép.
Bụt chạy rồi thì mấy kỹ sư biết kêu ai?
Vì rất rất nhiều kỹ sư, vẫn khóc lóc, và Bụt hiện lên hỏi:
- Ếch con, tại sao con khóc???-
Hôm qua, 15:37 -
27-04-2025, 08:30 -
27-04-2025, 07:21 -
27-04-2025, 07:02 -
bởi vi van phamNhắn tin khẩn:
27-04-2025, 05:57 -
26-04-2025, 23:16 -
26-04-2025, 21:33 -
26-04-2025, 20:52 -
Trả lời cho Tổng hợp quạt điện : điện tử , Cơ , phun sươngbởi Nikon57Mình có cái quạt trần điện cơ, xông điện vào không chạy . Dỡ xuống tháo ra quan sát thấy một đầu dây trong một bối dây bị đứt thò ra goài. Quạt cố, cả cuộn làm việc và cuồn đề bố trí thành một vòng . Xin xem ảnh kèm theo. Đo trở...
26-04-2025, 15:09 -
