Đồng hồ số giúp gấp,
  • #31
    #include<stdio.h>
    #include<reg52.h>
    #include<i2c.h>
    #include<ds1307.h>
    sbit led1=P0^0;
    sbit led2=P0^1;
    sbit led3=P0^2;
    sbit led4=P0^3;
    sbit led5=P0^4;
    sbit led6=P0^5;
    sbit set=P3^4;
    sbit up=P3^5;
    sbit down=P3^6;
    sbit f=P3^7;
    unsigned char hour, minute, second,thu=2,ngay=1,thang=1,nam=0;
    unsigned char ma[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x9 0};
    unsigned char kt=0,a=0,b=0,c=0,d=0,i,k,x=0;
    unsigned int y=0;
    bit set0=1,set1=1,up1=1,up0=1,down0=1,down1=1;
    void delays(int ms)
    int j;
    for(j=0;j<ms;j++){}
    /*void dem() interrupt 3
    TR1=0;
    TH1=-5000/256;
    TL1=-5000%256;
    c++;
    if(c==100)
    f=~f;
    TF1=0;
    TR1=1;
    void writeds(){
    rtc_write(0x00, second);
    rtc_write(0x01, minute);
    rtc_write(0x02, hour);
    rtc_write(0x03, thu);
    rtc_write(0x04, ngay);
    rtc_write(0x05, thang);
    rtc_write(0x06, nam);
    void readds()
    if(kt==0)
    if(a==1)
    {writeds();a=0;
    second = rtc_read(0x00);
    minute = rtc_read(0x01);
    hour = rtc_read(0x02);
    thu = rtc_read(0x03);
    ngay = rtc_read(0x04);
    thang = rtc_read(0x05);
    nam = rtc_read(0x06);
    void dislay()
    if(y>=20&&y<260)
    P2=ma[hour/10];led1=1;delays(90);led1=0;P2=0xff;
    P2=ma[hour%10];led2=1;delays(90);led2=0;P2=0xff;
    P2=ma[minute/10];led3=1;delays(90);led3=0;P2=0xff;
    P2=ma[minute%10];led4=1;delays(90);led4=0;P2=0xff;
    P2=ma[second/10];led5=1;delays(90);led5=0;P2=0xff;
    P2=ma[second%10];led6=1;delays(90);led6=0;P2=0xff;
    if(y>=260&&y<280)
    P2=0xce;led1=1;delays(90);led1=0;P2=0xff;
    P2=ma[thu];led2=1;delays(90);led2=0;P2=0xff;
    P2=ma[ngay/10];led3=1;delays(90);led3=0;P2=0xff;
    P2=ma[ngay%10];led4=1;delays(90);led4=0;P2=0xff;
    P2=ma[thang/10];led5=1;delays(90);led5=0;P2=0xff;
    P2=ma[thang%10];led6=1;delays(90);led6=0;P2=0xff;
    if(y>=280&&y<300)
    P2=ma[2];led2=1;delays(90);led2=0;P2=0xff;
    P2=ma[0];led3=1;delays(90);led3=0;P2=0xff;
    P2=ma[nam/10];led4=1;delays(90);led4=0;P2=0xff;
    P2=ma[nam%10];led5=1;delays(90);led5=0;P2=0xff;
    if(y<20)
    led6=0;
    P2=0x89;led1=1;delays(90);led1=0;P2=0xff;
    P2=0x86;led2=1;delays(90);led2=0;P2=0xff;
    P2=0xc7;led3=1;delays(90);led3=0;P2=0xff;
    P2=0xc7;led4=1;delays(90);led4=0;P2=0xff;
    P2=0xc0;led5=1;delays(90);led5=0;P2=0xff;
    void ktphim()
    set0=set1;set1=set;
    if((set0==1)&&(set1==0))
    kt++;
    if(kt>7)kt=0;
    switch(kt)
    case 0:break;
    case 1:
    up0=up1;up1=up; a=1;b=1;d=1;
    if((up0==1)&&(up1==0))
    hour++;
    if(hour>23)hour=0;
    down0=down1;down1=down;
    if((down0==1)&&(down1==0))
    hour--;
    if(hour==-1)
    hour=23;
    break;
    case 2:
    minute++;
    if(minute>59)
    minute=0;
    minute--;
    if(minute==-1)
    minute=59;
    break;
    case 3:
    up0=up1;up1=up;a=1;b=1;d=1;
    second++;
    if(second>59)
    second=0;
    second=0;
    break;
    case 4:
    up0=up1;up1=up; a=1;b=2;d=1;
    thu++;
    if(thu>7)thu=1;
    thu--;
    if(thu==0)
    thu=7;
    break;
    case 5:
    ngay++;
    if(ngay>31)ngay=1;
    ngay--;
    if(ngay==0)
    ngay=31;
    break;
    case 6:
    thang++;
    if(thang>12)thang=1;
    thang--;
    if(thang==0)
    thang=12;
    break;
    case 7:
    up0=up1;up1=up; a=1;b=3;d=1;
    nam++;
    if(nam>99)nam=0;
    nam--;
    if(nam==0)
    nam=99;
    break;
    void chinhgio(void)
    if(b==1)
    if((kt==0)||(kt!=1)||((kt==1)&&(x<40)))
    P2=ma[hour/10];led1=1;delays(100);led1=0;P2=0xff;
    P2=ma[hour%10];led2=1;delays(100);led2=0;P2=0xff;
    if((kt==0)||(kt!=2)||((kt==2)&&(x<40)))
    P2=ma[minute/10];led3=1;delays(100);led3=0;P2=0xff;
    P2=ma[minute%10];led4=1;delays(100);led4=0;P2=0xff;
    if((kt==0)||(kt!=3)||((kt==3)&&(x<40)))
    P2=ma[second/10];led5=1;delays(100);led5=0;P2=0xff;
    P2=ma[second%10];led6=1;delays(100);led6=0;P2=0xff;
    if(b==2)
    if((kt==0)||(kt!=4)||((kt==4)&&(x<40)))
    P2=0xce;led1=1;delays(100);led1=0;P2=0xff;
    P2=ma[thu];led2=1;delays(100);led2=0;P2=0xff;
    if((kt==0)||(kt!=5)||((kt==5)&&(x<40)))
    P2=ma[ngay/10];led3=1;delays(100);led3=0;P2=0xff;
    P2=ma[ngay%10];led4=1;delays(100);led4=0;P2=0xff;
    if((kt==0)||(kt!=6)||((kt==6)&&(x<40)))
    P2=ma[thang/10];led5=1;delays(100);led5=0;P2=0xff;
    P2=ma[thang%10];led6=1;delays(100);led6=0;P2=0xff;
    if(b==3)
    if((kt==0)||(kt!=7)||((kt==7)&&(x<40)))
    P2=ma[2];led2=1;delays(100);led2=0;P2=0xff;
    P2=ma[0];led3=1;delays(100);led3=0;P2=0xff;
    P2=ma[nam/10];led4=1;delays(100);led4=0;P2=0xff;
    P2=ma[nam%10];led5=1;delays(100);led5=0;P2=0xff;
    void bugio(void)
    if((hour==23 )&& (minute==59)&&(second==56))
    hour=0;
    minute=0;
    second=0;
    writeds();
    void main()
    /* TMOD=0x10;
    TH1=-10000/256;
    TL1=-10000%256;
    ET1=1;
    ET0=1;
    EA=1;
    IE=0X88;
    IP=0;
    TF1=0;
    TR1=1; */
    while(1)
    y++;
    x++;
    ktphim();
    readds();
    if(d==0)
    dislay();
    if(d==1)
    chinhgio();
    d=0;
    bugio();
    if(x==80)
    {x=0;}
    if(y==300)
    {y=0;}
    Các bạn ktra giúp mình cái code này với nhé xem có đúng là nó có vấn đề ko nhé,
    • #32
      while(1)
      y++;
      x++;
      ktphim();
      readds();//nếu hàm này mất khoảng 60ms thì led nháy
      //trong hàm readds() bạn chỉ cho đọc giá trị giây rồi hiển thị xem led nó còn nháy không.
      if(d==0)
      dislay();
      if(d==1)
      chinhgio();
      d=0;
      bugio();
      if(x==80)
      {x=0;}
      if(y==300)
      {y=0;}
      • #33
        Chào bạn, bạn có thể chỉnh sửa lại giúp mình với được ko ? vì khi chỉnh như ý bạn nói nó vẫn nháy à, có gì nhờ bạn giúp với nhé, cảm ơn bạn rất nhiều.
        • #34
          thế rốt cục là mạch của bạn bị vấn đề j vậy mà giờ đã chạy ngon roài!! bạn đã chỉnh sửa lại những j vậy? bạn nói cho mọi người cùng biết và rút kinh nghiệm!
          • #35
            chỉ chỉnh lại code thôi nhưng giờ nó lại bị hiện tượng là các led chạy bị giật và độ sang ko được tốt, mình thay con tran A1015=C1815
            • #36
              có bạn nao huong dan cho minh cach khac phuc tinh trang dong ho cua minh ding 89c52 da chay ngon lanh roi nhung co co ban de nhu the nay.khi led nhay tat cac thanh nhung khi thanh đó tắt mà van con 1 so bong con sang k tắt hẳng minh da xu lý nhieu cách nhung k dc.k hieu ic dong quet co ban de j k nua
              • #37
                bạn nên kiểm tra phần quét led của mình xem. hiện tượng đó hình như mọi người gọi là " ma lem" hay bóng ma gì đó. cái này mình đã từng bị rùi, cách xử lí của mình là chèn thêm thời gian tắt vào giữa các lần bóng sáng luân phiên.
                đây là đoạn code của mình :
                void hienthi(unsigned char n1,unsigned char n2,unsigned char n3,unsigned char n4,unsigned char n5,unsigned char n6,unsigned char time)
                unsigned char n;
                led1=0;led2=0;led3=0;led4=0;led5=0;led6=0;P1=0;
                for(n=0;n<time;n++)
                P1=a[n1];led1=1;delay();led1=0;led1=0;P1=0; ( đoạn Led1=0;led1=0;P1=0; là phần thêm vào để cho hết bóng ma)
                P1=a[n2];led2=1;delay();led2=0;led2=0;P1=0;
                P1=a[n3];led3=1;delay();led3=0;led3=0;P1=0;
                P1=a[n4];led4=1;delay();led4=0;led4=0;P1=0;
                P1=a[n5];led5=1;delay();led5=0;led5=0;P1=0;
                P1=a[n6];led6=1;delay();led6=0;P1=0;
                chỉ có tâm hồn là nơi duy nhất: có thể biến thiên đường thành địa ngục và ngược lại có thể biến địa ngục hóa thiên đường
                Everything should be made as simple as possible, but not simpler
                hahai Tìm hiểu thêm về hahai
