bạn download trên mạng về là xài được à.
Clock 8051+DS1307: hiển thị Giờ + Phút + Giây + Ngày trong tuần + ngày + tháng + năm
Code DS1307:
#define WRITE 0xd0
#define READ 0xd1
#define SEC 0
#define MIN 1
#define HOUR 2
#define DAY 3
#define DATE 4
#define MONTH 5
#define YEAR 6
#define CONTROL 7
#define BYTE_COUNT 7
#define NVRAM_START 8
#define HZ 0x10
char gca_ds1307[BYTE_COUNT];
// char ngay_thang[3];
char bin_bcd(char bin)
char temp,i;
temp = bin;
i = 0;
while(1)
if(temp>=10)
temp -= 10;
i += 0x10;
else
i += temp;
return i;
char bcd_bin(char bcd)
char temp;
temp = bcd;
temp >>= 1;
temp &= 0x78;
return (temp+(temp >> 2)+(bcd & 0x0f));
void DS1307_Set()
char i;
for(i=0;i<7;i++)
gca_ds1307[i]=bin_bcd(gca_ds1307[i]);
gca_ds1307[SEC] &= 0x7F;
gca_ds1307[HOUR] &= 0x3F;
disable_interrupts(GLOBAL);
i2c_start();
i2c_write(WRITE);
i2c_write(SEC);
for(i=0;i<7;i++)
i2c_write(gca_ds1307[i]);
i2c_write(HZ);
i2c_stop();
enable_interrupts(GLOBAL);
void DS1307_Read()
char i;
i2c_start();
i2c_write(WRITE);
i2c_write(SEC);
i2c_start();
i2c_write(READ);
gca_ds1307[SEC] = i2c_read() & 0x7F;
gca_ds1307[MIN] = i2c_read() & 0x7F;
gca_ds1307[HOUR] = i2c_read() & 0x3F;
gca_ds1307[DAY] = i2c_read() & 0x7F;
gca_ds1307[DATE] = i2c_read() & 0x3F;
gca_ds1307[MONTH] = i2c_read() & 0x1F;
gca_ds1307[YEAR] = i2c_read(0);
i2c_stop();
for(i=0;i<7;i++)
gca_ds1307[i]=bcd_bin(gca_ds1307[i]);
char Read_Byte(char addr)
char i;
i2c_start();
i2c_write(WRITE);
i2c_write(addr);
i2c_start();
i2c_write(READ);
i = i2c_read(0);
i2c_stop();
return i;
void Write_Byte(char addr,char n)
i2c_start();
i2c_write(WRITE);
i2c_write(addr);
i2c_write(n);
i2c_stop();
Code LCD16x2:
THE 1602 CHAR LCD LIB
COPYRIGHT (c) 2005 BY JJJ.
-- ALL RIGHTS RESERVED --
File Name: LCD.h
Author: Jiang Jian Jun
Created: 2005/4/3
Modified: NO
Revision: 1.0
#ifndef LCD_CHAR_1602_2005_4_9
#define LCD_CHAR_1602_2005_4_9
#include <intrins.h>
//Port Definitions*************************************** *******************
sbit LcdRs = P2^0;
sbit LcdRw = P2^1;
sbit LcdEn = P2^2;
sfr DBPort = 0x80; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.Êý¾Ý¶Ë¿Ú
//ÄÚ²¿µÈ´ýº¯Êý************************************** ************************************
unsigned char LCD_Wait(void)
LcdRs=0;
LcdRw=1; _nop_();
LcdEn=1; _nop_();
//while(DBPort&0x80);//ÔÚÓÃProteus·ÂÕæʱ£¬×¢ÒâÓÃÆÁ±Î´ËÓï¾ä£¬ÔÚµ÷ÓÃGotoXY( )ʱ£¬»á½øÈëËÀÑ»·£¬
//¿ÉÄÜÔÚд¸Ã¿ØÖÆ×Öʱ£¬¸ÃÄ£¿éûÓзµ»ØдÈëÍ걸ÃüÁ¼´ DBPort&0x80==0x80
//ʵ¼ÊÓ²¼þʱ´ò¿ª´ËÓï¾ä
LcdEn=0;
return DBPort;
//ÏòLCDдÈëÃüÁî»òÊý¾Ý******************************* *****************************
#define LCD_COMMAND 0 // Command
#define LCD_DATA 1 // Data
#define LCD_CLEAR_SCREEN 0x01 // ÇåÆÁ
#define LCD_HOMING 0x02 // ¹â±ê·µ»ØÔµã
void LCD_Write(bit style, unsigned char input)
LcdEn=0;
LcdRs=style;
LcdRw=0; _nop_();
DBPort=input; _nop_();//×¢Òâ˳Ðò
LcdEn=1; _nop_();//×¢Òâ˳Ðò
LcdEn=0; _nop_();
LCD_Wait();
//ÉèÖÃÏÔʾģʽ************************************** **********************
#define LCD_SHOW 0x04 //ÏÔʾ¿ª
#define LCD_HIDE 0x00 //ÏÔʾ¹Ø
#define LCD_CURSOR 0x02 //ÏÔʾ¹â±ê
#define LCD_NO_CURSOR 0x00 //ÎÞ¹â±ê
#define LCD_FLASH 0x01 //¹â±êÉÁ¶¯
#define LCD_NO_FLASH 0x00 //¹â±ê²»ÉÁ¶¯
void LCD_SetDisplay(unsigned char DisplayMode)
LCD_Write(LCD_COMMAND, 0x08|DisplayMode);
//ÉèÖÃÊäÈëģʽ************************************** **********************
#define LCD_AC_UP 0x02
#define LCD_AC_DOWN 0x00 // default
#define LCD_MOVE 0x01 // »Ãæ¿ÉƽÒÆ
#define LCD_NO_MOVE 0x00 //default
void LCD_SetInput(unsigned char InputMode)
LCD_Write(LCD_COMMAND, 0x04|InputMode);
//Òƶ¯¹â±ê»òÆÁÄ»************************************ ************************
#define LCD_SCREEN 0x08
#define LCD_LEFT 0x00
#define LCD_RIGHT 0x04
void LCD_Move(unsigned char object, unsigned char direction)
if(object==LCD_CURSOR)
LCD_Write(LCD_COMMAND,0x10|direction);
if(object==LCD_SCREEN)
LCD_Write(LCD_COMMAND,0x18|direction);
//³õʼ»¯LCD***************************************** *******************
void LCD_Initial()
LcdEn=0;
LCD_Write(LCD_COMMAND,0x38); //8λÊý¾Ý¶Ë¿Ú,2ÐÐÏÔʾ,5*7µãÕó
LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR); //¿ªÆôÏÔʾ, ÎÞ¹â±ê
LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //ÇåÆÁ
LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE); //ACµÝÔö, »Ãæ²»¶¯
void GotoXY(unsigned char x, unsigned char y)
if(y==0)
LCD_Write(LCD_COMMAND,0x80|x);
if(y==1)
LCD_Write(LCD_COMMAND,0x80|(x-0x40));
void Print(unsigned char *str)
while(*str!='\0')
LCD_Write(LCD_DATA,*str);
str++;
void LCD_LoadChar(unsigned char user[8], unsigned char place)
unsigned char i;
LCD_Write(LCD_COMMAND,0x40|(place*8));
for(i=0; i<8; i++)
LCD_Write(LCD_DATA,user[i]);
#endif
hi bạn ơi! mình chờ hồi âm của bạn mãi mà không thấy, bạn có thể gửi mail nguyensiluan@gmail.com cho mình 2 thư viện đó được không? nếu ở trên mạng có , bạn gửi link cho mình cũng được, cám ơn bạn trước!
Nguyên văn bởi chau0105_bt Xem bài viết
bạn ơi mình downd về biên dịch thử nó báo lỗi này! hình như thư viện không phải của chương trình này thì phải: Clock van nien mach thuc_LCD16x2
bạn cho mình cái file gốc đi!!!
Nguyên văn bởi chjpchjp1991Bạn down về nhưng phải xem định nghĩa file chuẩn với file main chưa..rồi chân trong các file đó..rồi kiểm tra các hàm lệnh có khớp để gọi không, mình không lập trình được món Đồng Hồ này nhưng cũng biết sơ sơ chân vào ra mấy tí..^^"
Nguyên văn bởi chjpchjp1991Mình nhìn thư viện LCD cũng quen lắm..chương trình của bạn ấy..nhưng không nhớ là ở chỗ nào..ngày trước có tháy..giờ tìm không ra..Thôi chấp nhận đi bạn lee_nguyen..không có xài theo kiểu ko có..^^"
Nguyên văn bởi chjpchjp1991me too...Mình cũng có đồng hồ LCD nhưng chứ có mấy món âm lich ^^
Nguyên văn bởi viboyth.haui Xem bài viếtHiển thị giờ phút giây ngày tháng năm trên LCD
Dong Ho Thoi Gian Thuc LCD.rar
cho m hỏi ké nhe , m dùng tip 41 kéo led 7 đoạn ( Led 7 Thanh 1.2 Inch Anot 1 Số(3x4cm)_LED 7 Thanh_LED_BanLinhKien.Vn - MinhHaGroup.Com ) , nhưng giả sử độ sáng khi cấp nguồn + vào chân anot là 100% thì , m dùng tip chỉ đc 70 % , m test thử thấy bỏ trở từ chân điều khiển đến chân B tip 41 thì led sáng hơn , và dùng típ sáng hơn C1815 , và nếu mắc thêm trzito C18515 đệm cho Tip , led vẫn sáng thế
http://nw3.upanh.com/b3.s36.d1/2ebcc...3.untitled.bmp
( chả hiu sao , tải file lên k đc )
bởi sonnenDịch vụ son nen nha xuong gia re thi công sơn Epoxy tại TPHCM thi cong son epoxy gia re
- Thi công sơn sàn ở nhà kho nhà xưởng các KCN chạy dài từ Nam ra Bắc son nen nha xuong
- Thi công công trình mới hay bảo dưỡng sửa chữa giải đáp các vấn đề nan giải của nhiều khách
Channel: Quảng cáo
hôm nay, 16:28 -
Hôm qua, 14:40 -
Hôm qua, 06:08 -
Hôm qua, 01:38 -
Hôm qua, 01:26 -
14-02-2025, 00:42 -
13-02-2025, 17:02 -
13-02-2025, 08:43 -
