các pro cho E hỏi về cái lập trình Keil C cho LED matrix
E đang làm bt lớn về Mạch LED matrix 16x64, nhưng mà đang mắc cái phần viết chương trình, hôm trước E nhờ A Ngô Hải Bắc, Nhưng A đang bận
E sưu tầm dc 1 cái code trên mạng về.
và file FONT_CODE.H
code:
khai báo unsigned char code Bmp002[]={}
thì lấy những giá trị kia bằng cách nào, theo e biết đó la mã ký tự
rất mong dc các pro jup đỡ ạ
và file FONT_CODE.H
code:
Code:
unsigned char code Bmp002[]= { /*------------------------------------------------------------------------------ ; If font display distortion, please check Fonts format of setup. ; Source file / text : Líp ®iÖn tö K2 ; Width x Height (pixels) :243X16 ; Font Format/Size : Monochrome LCD Fonts ,Horizontal scan ,Big endian order/496Byte ; Font make date : 10/11/2009 7:32:20 AM ------------------------------------------------------------------------------*/ 0xF3,0x10,0x1F,//Width pixels,Height pixels,Width bytes 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x01,0x00,0x00,0x00, 0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x01,0xFE,0x01,0x80,0x00,0x00,0x1F,0x3C,0x38,0x00,0x00, 0x00,0x01,0x00,0x3F,0x9F,0x1F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0xF8,0x03,0x00,0x00,0x00,0x7F,0xBC,0x28,0x00,0x00,0x02, 0x02,0x18,0x1F,0x08,0x63,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0xF8,0x04,0x38,0x00,0x00,0x0F,0x3C,0x64,0x00,0x00,0x06,0x04, 0x38,0x1F,0x10,0x7B,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0xF8,0x00,0x38,0x00,0x00,0x4F,0x00,0x00,0x00,0x00,0x0E,0x00,0x3C, 0x1F,0x30,0x7B,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0xF8,0x07,0xF3,0xEE,0x01,0xFF,0x7C,0x7C,0x7D,0xC0,0x3F,0xFF,0xF0,0x1F, 0x78,0x03,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0xF8,0x0E,0x79,0xFF,0x01,0xEF,0x3C,0xEE,0x3F,0xE0,0x1E,0x3D,0xE0,0x1F,0xF8, 0x03,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xF8,0x1E,0x79,0xEF,0x83,0xEF,0x3D,0xEF,0x3D,0xE0,0x1E,0x3D,0xE0,0x1F,0x7C,0x0E, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8, 0x5E,0x79,0xEF,0x83,0xEF,0x3D,0xFF,0x3D,0xE0,0x1E,0x3D,0xE0,0x1F,0x7E,0x10,0x20, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x5E, 0x79,0xEF,0x03,0xEF,0x3D,0xE0,0x3D,0xE0,0x1E,0xBD,0xE0,0x1F,0x3E,0x2F,0xE0,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xCE,0x71, 0xEF,0x01,0xEF,0x3C,0xE1,0x3D,0xE0,0x1E,0xBD,0xE0,0x1F,0x1F,0x7F,0xE0,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xC7,0xE1,0xFE, 0x00,0xFF,0xFE,0x76,0x7D,0xF0,0x1F,0x3F,0xF0,0x3F,0xBF,0xFF,0x80,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xE0,0x00, 0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xE0,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00, 0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF0,0x00,0x00,0x00,0x38, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, };
