có bạn nào lam về giao tếp I2C thì giúp mình với:
đoạn code sau của mình ko ghi đọc đc ROM.
Mình dùng con ROM 24c64
Code:
#include <AT89X51.H> #include <regx51.h> sbit SCL = P0^4; sbit SDA = P0^3; void Ack(void); void Delay(unsigned int loop); unsigned char ReadROM(unsigned int addr); void WriteROM(unsigned int addr, unsigned char); void WriteByte(unsigned char bytout); void Delay(unsigned int loop) { while(loop--) ; } void BaseClock(void) //tao xung nhip tren SCL { Delay(4); SCL = 1; Delay(4); SCL = 0; } void Ack(void) // tin hieu ACK tu Master { SDA = 0; BaseClock(); SDA = 1; } void StartBit(void) //Tao bit Start { SCL = 1; SDA = 1; Delay(4); SDA = 0; Delay(4); SCL = 0; } void StopBit(void) //Bit Stop { SCL = 0; SDA = 0; SCL = 1; Delay(4); SDA = 1; Delay(4); SCL = 0; } void SetupRom(void) // Thiet lap ROM { unsigned char i; SCL = 1; SDA = 1; Delay(2); for(i=0;i<8;i++) BaseClock(); StartBit(); } void NoAck(void) { SDA = 1; BaseClock(); } void WaitTwr(void) { Delay(400); } void WriteByte(unsigned char bytout) // Ghi 1 Byte len ROM { unsigned char i; for(i=0;i<8;i++) { if((bytout & 0x80) == 0x00) SDA = 0; else SDA = 1; BaseClock(); bytout = bytout << 1; } } unsigned char ReadByte(void) //Doc 1 Byte tu ROM { unsigned char i,bytin; bit read; bytin = 0; bytin = bytin | SDA; for(i=0;i<8;i++) { BaseClock(); read = SDA; bytin = bytin << 1; bytin = bytin | read; } return(bytin); } void WriteROM(unsigned int addr, unsigned char ch) //ghi ch vao ROM tai dia chi addr { StartBit(); WriteByte(0xA0); Ack(); WriteByte(addr&0xF0); Ack(); WriteByte(addr&0x0F); Ack(); WriteByte(ch); Ack(); StopBit(); WaitTwr(); } unsigned char ReadROM(unsigned int addr) //Doc ROM tu dia chi addr { unsigned char ch; StartBit(); WriteByte(0xA0); Ack(); WriteByte(addr&0xF0); Ack(); WriteByte(addr&0x0F); Ack(); StartBit(); WriteByte(0xA1); Ack(); ch = ReadByte(); NoAck(); StopBit(); return(ch); }
