giúp đỡ về đoạn code
  • giúp đỡ về đoạn code
    anh em nao giải thích đoạn code này với. xin giải thích từng dòng từng câu lệnh giúp mình với.thanks anh em nhé.
    LachCK bit p3.0
    ShiftCK bit p3.1
    SData bit p3.2
    H1 bit p2.0
    H2 bit p2.1
    H3 bit p2.2
    H4 bit p2.3
    H5 bit p2.4
    H6 bit p2.5
    H7 bit p2.6
    H8 bit p2.7
    PortCT equ p2
    AdcData equ p0
    AdcCs bit p1.0
    AdcRd bit p1.1
    AdcWr bit p1.2
    AdcIntr bit p1.3
    MaxVolt equ 20 ;max 99V
    DataBuff equ 80h
    MatrixBuff equ 90h
    org 0h
    org 30h
    mainf:
    mov r7,#01h
    mov PortCT,#0ffh
    mov p3,#0
    mov p1,#0ffh
    call Resetdata
    call LoadData
    mov 60h,#5
    main:
    call scanmt
    mov a,r7
    rl a
    mov r7,a
    call delay
    cjne a,#80h,main
    djnz 60h,main
    mov 60h,#20
    call ReadAdc
    call VoltConvert
    call LoadData
    jmp main
    ;data return in Acc
    ReadAdc:
    push 0
    clr AdcCs
    clr AdcWr
    nop
    setb AdcWr
    setb AdcWr
    jb AdcIntr,$
    mov r0,#10
    djnz r0,$
    clr AdcCs
    clr AdcRd
    nop
    mov a,AdcData
    setb AdcRd
    setb AdcCs
    pop 0
    ret
    ;volt = data* Maxvolt/255
    VoltConvert:
    push 0
    push 5
    push 6
    push 7
    mov r0,#DataBuff
    mov b,#MaxVolt
    mul ab
    mov r7,b
    mov r6,a
    mov b,#255
    call DIV_16_8
    mov r5,b
    mov a,r6
    mov b,#10
    div ab
    mov @r0,a
    inc r0
    mov @r0,b
    mov a,r5
    mov b,#10
    mul ab
    mov r7,b
    mov r6,a
    mov b,#255
    call DIV_16_8
    inc r0
    mov a,r6
    mov @r0,a
    pop 7
    pop 6
    pop 5
    pop 0
    ret
    ;so chia trong r7,r6
    ;so bi chia trong b
    ;ket qua trong r7,r6
    ;so du trong b
    DIV_16_8: push 02h
    push acc
    mov r2,#16
    clr a
    _div001: xch a,r6
    clr c
    rlc a
    xch a,r6
    xch a,r7
    rlc a
    xch a,r7
    rlc a
    jnc _div002
    clr c
    sjmp _div004
    _div002: cjne a,b,_div003
    jmp _div004
    _div003: jc _div005
    _div004: subb a,b
    xch a,r6
    orl a,#1
    xch A,R6
    _div005: djnz r2,_div001
    xch a,b
    pop acc
    pop 02h
    RET
    scanmt:
    push acc
    push 0
    push 6
    mov r0,#MatrixBuff+31
    mov r6,#32
    mov PortCT,#0h
    rescan:
    mov a,@r0
    anl a,r7
    cjne a,#0,scdtset
    clr SData
    jmp scdtshift
    scdtset:
    setb SData
    scdtshift:
    setb ShiftCK
    clr ShiftCK
    dec r0
    djnz r6,rescan
    setb LachCK
    clr LachCK
    mov PortCT,r7
    pop 6
    pop 0
    pop acc
    ret
    delay:
    mov 51h,#10
    dl1: mov 50h,#100
    djnz 50h,$
    djnz 51h,dl1
    ret
    ResetData:
    mov r0,#MatrixBuff
    mov a,#0ffh
    mov r1,#24
    Resetdt:
    mov @r0,a
    inc r0
    djnz r1,Resetdt
    ret
    LoadData:
    mov r0,#MatrixBuff
    mov r1,#DataBuff
    Loaddt2:
    mov r2,#8
    mov a,@r1
    call LoadDptr
    mov r3,a
    Loaddt1:
    movc a,@a+dptr
    mov @r0,a
    inc r3
    inc r0
    mov a,r3
    djnz r2,Loaddt1
    inc r1
    cjne r1,#DataBuff+3,Loaddt2
    mov r2,#8
    mov dptr,#LTV
    mov r3,#0
    Loaddt3:
    mov a,r3
    movc a,@a+dptr
    mov @r0,a
    inc r3
    inc r0
    djnz r2,Loaddt3
    mov r0,#MatrixBuff+15
    mov a,@r0
    anl a,#0feh
    mov @r0,a
    ret
    ;in a = 0-->9
    ;out a+dptr -> 0--9 of dptr
    LoadDptr:
    mov dptr,#LetterCode
    mov b,#8
    mul ab
    ret
    LetterCode:
    DB 0FFh,0C1H,0BEH,0BEH,0BEH,0C1H,0FFH,0FFH
    DB 0ffh,0FEH,0DEH,80H,0FEH,0FEH,0FFH,0FFH
    DB 0ffh,0DEH,0BCH,0BAH,0B6H,0CEH,0FFH,0FFH
    DB 0ffh,0DDH,0BEH,0B6H,0B6H,0C9H,0FFH,0FFH
    DB 0ffh,0F3H,0EBH,0DBH,80H,0FBH,0FFH,0FFH
    DB 0FFH,8DH,0AEH,0AEH,0AEH,0B1H,0FFH,0FFH
    DB 0ffh,0C1H,0B6H,0B6H,0B6H,0D9H,0FFH,0FFH
    DB 0ffh,9FH,0BFH,0B0H,0AFH,9FH,0FFH,0FFH
    DB 0ffh,0C9H,0B6H,0B6H,0B6H,0C9H,0FFH,0FFH
    DB 0ffh,0CDH,0B6H,0B6H,0B6H,0C1H,0FFH,0FFH
    LTV: DB 0ffh,83H,0FDH,0FEH,0FDH,83H,0FFH,0FFH
    end
    mình theo C ko theo ASM nên ko hiểu cái code này nhưng mà bận yêu cầu giải thích từng dòng từng cột chắc chả có ma nào ngó ngàng đâu, hãy chỉ đoạn nào bạn khó hiểu thắc mắc thì đánh dấu vào đó thôi, chứ làm j có ai ngồi check hết cái đống code này được mà cũng chả biết code cho cái j, bạn nên có kèm file nguyên lý thì việc nhận xét sẽ dễ dàng hơn
    Website chính thức đổi địa chỉ website thành
    Mời các bạn ghé thăm !!!
      [QUOTE=mast090;357693]mình theo C ko theo ASM nên ko hiểu cái code
      bạn này giống mình quá
        hiii.sorry a e nhé.mình gửi lên đó a e nào biết được lệnh nào dùng để làm j thì giải thích giúp mình chứ không cần phải giải thích hết đâu .http://www.mediafire.com/?99oh9nnj9xa730o đây là hình mà phần code ở trên đó
          hghjhfv
          phovanphan Tìm hiểu thêm về phovanphan
