Nguyên văn bởi rptdnmqs
các bác giúp sửa hộ e cái ct với help????
Nguyên văn bởi tdm Xem bài viếtthêm hiệu ứng:
Code:#include"reg52.h" char x,y,i,j,q,tong1; int tong2; const unsigned char ma_led[6][8]={ 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,//sang dan lsb..msb 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,//sang dan msb..lsb 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xff,//toi dan lsb..msb 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,//toi dan msb.lsb 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,//toi dan 1 led lsb...msb 0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//toi dan 1 led msb...lsb void delay(unsigned long int t) { unsigned long int l; for(l=0;l<t;l++); } void sang_dan() { P0=P1=P2=P3=0xff; for(x=0;x<=7;x++) { P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P3=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[1][x]; delay(2000); } for(x=0;x<=7;x++) { P0=ma_led[1][x]; delay(2000); } } void toi_dan() { P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P1=ma_led[2][x]; delay(2000); } for(x=0;x<=7;x++) { P3=ma_led[2][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[3][x]; delay(2000); } for(x=0;x<=7;x++) { P0=ma_led[3][x]; delay(2000); } } void toi_dan_1_led() { P0=P1=P2=P3=0x00; delay(2000); for(x=0;x<=7;x++) { P1=ma_led[4][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P3=ma_led[4][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P2=ma_led[5][x]; delay(2000); } for(x=0;x<=7;x++) { P0=ma_led[5][x]; delay(2000); } P0=P1=P2=P3=0x00; } void sang_2ben() { P0=P1=P2=P3=0xff; for(x=0;x<=7;x++) { P0=ma_led[0][x]; P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[0][x]; P3=ma_led[0][x]; delay(2000); } } void kieu_4() { for(x=0;x<=7;x++) { P0=ma_led[0][x]; P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[1][x]; P3=ma_led[1][x]; delay(2000); } } void kieu_5() { for(x=0;x<=7;x++) { P1=ma_led[0][x]; P3=ma_led[1][x]; P0=ma_led[0][x]; P2=ma_led[1][x]; delay(2000); } } void kieu_6() { for(x=0;x<=7;x++) { P0=ma_led[2][x]; P1=ma_led[2][x]; P2=ma_led[3][x]; P3=ma_led[3][x]; delay(2000); } } void nhap_nhay_nua() { P0=P1=P2=P3=0xff; for(x=0;x<=8;x++) { P0=P2=0x00; delay(2000); P0=P2=0xff; P1=P3=0x00; delay(2000); P1=P3=0xff; } } void nhap_nhay_nua_cheo() { P0=P1=P2=P3=0xff; for(x=0;x<=8;x++) { P2=P1=0x00; delay(2000); P2=P1=0xff; P0=P3=0x00; delay(2000); P0=P3=0xff; } } void da_hai() { for(x=0;x<=8;x++) { P0=P1=P2=P3=0x55; delay(2000); P0=P1=P2=P3=0xaa; delay(2000); } } void nhap_nhay() { for(x=0;x<=8;x++) { P0=P1=P2=P3=0x00; delay(2000); P0=P1=P2=P3=0xff; delay(2000); } } void main() { while(1) { sang_dan(); nhap_nhay(); toi_dan(); nhap_nhay(); sang_2ben(); nhap_nhay(); kieu_4() ; nhap_nhay(); kieu_5() ; nhap_nhay(); kieu_6() ; nhap_nhay(); nhap_nhay_nua(); nhap_nhay(); da_hai(); toi_dan_1_led(); nhap_nhay(); da_hai(); nhap_nhay_nua_cheo(); nhap_nhay(); } }
Gmail:
Nguyên văn bởi rptdnmqs Xem bài viếtVí dụ:nếu file hex 7k thì giá trị gần đúng trong rom là 3.5k(gần dúng nhất tầm 3k thôi)
Gmail:
Gmail:
Nguyên văn bởi ckd08 Xem bài viếtCode của mình bình thường mà bác
MVI 0005 - YouTube
Gmail:
Nguyên văn bởi ckd08 Xem bài viếtMình làm bằng con 89s52. Bác đi mua con 89s52 về lắp vào cũng được mà, giá có 22k thì phải. Chân cẳng giống nhau hết, 89s52 thì 8kb và có thể nạp nối tiếp.
Gmail:
Nguyên văn bởi tuankep6 Xem bài viếtthì tất nhiên có con 52 thì phải hơn rùi nhưng chẳng lẽ đy hơn trăm cây để mua em nó.thôi khi khác có dịp thì đy 1 thể.mà bác bảo nạp nối tiếp là sao nhỉ k hiểu
Mình đang xài 1 cái như thế này, nạp cho cả 89 và avr
Nguyên văn bởi ckd08 Xem bài viếtBình thường con 89c của bác phải gỡ ra, cho vào mạch mới nạp được. Còn 89s thì có 3 chân tạo xung mosi, miso, sck, cộng thêm chân rst với gnd nữa là chỉ cần cắm dây nạp ( cổng com, lpt, usb) là có thể nạp được trực tiếp luôn, không phải gỡ chip.
Gmail:
Nguyên văn bởi tuankep6 Xem bài viếtmà đây e nạp vào chíp rồi thấy có 1 hiệu ứng 1 led chạy đến gần cuối có 1 con led vẫn sáng kia bác sửa sao đây http://www.youtube.com/user/tuankep6?feature=mheehttp://www.youtube.com/user/tuankep6?feature=mhee
Code:#include"reg52.h" char x,y,i,j,q,tong1; int tong2; const unsigned char ma_led[6][8]={ 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,//sang dan lsb..msb 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,//sang dan msb..lsb 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xff,//toi dan lsb..msb 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,//toi dan msb.lsb 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,//toi dan 1 led lsb...msb 0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//toi dan 1 led msb...lsb void delay(unsigned long int t) { unsigned long int l; for(l=0;l<t;l++); } void sang_dan() { P0=P1=P2=P3=0xff; for(x=0;x<=7;x++) { P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P3=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[1][x]; delay(2000); } for(x=0;x<=7;x++) { P0=ma_led[1][x]; delay(2000); } } void toi_dan() { P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P1=ma_led[2][x]; delay(2000); } for(x=0;x<=7;x++) { P3=ma_led[2][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[3][x]; delay(2000); } for(x=0;x<=7;x++) { P0=ma_led[3][x]; delay(2000); } } void toi_dan_1_led() { P0=P1=P2=P3=0x00; delay(2000); for(x=0;x<=7;x++) { P1=ma_led[4][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P3=ma_led[4][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P2=ma_led[5][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P0=ma_led[5][x]; delay(2000); } P0=P1=P2=P3=0x00; } void sang_2ben() { P0=P1=P2=P3=0xff; for(x=0;x<=7;x++) { P0=ma_led[0][x]; P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[0][x]; P3=ma_led[0][x]; delay(2000); } } void kieu_4() { for(x=0;x<=7;x++) { P0=ma_led[0][x]; P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[1][x]; P3=ma_led[1][x]; delay(2000); } } void kieu_5() { for(x=0;x<=7;x++) { P1=ma_led[0][x]; P3=ma_led[1][x]; P0=ma_led[0][x]; P2=ma_led[1][x]; delay(2000); } } void kieu_6() { for(x=0;x<=7;x++) { P0=ma_led[2][x]; P1=ma_led[2][x]; P2=ma_led[3][x]; P3=ma_led[3][x]; delay(2000); } } void nhap_nhay_nua() { P0=P1=P2=P3=0xff; for(x=0;x<=8;x++) { P0=P2=0x00; delay(2000); P0=P2=0xff; P1=P3=0x00; delay(2000); P1=P3=0xff; } } void nhap_nhay_nua_cheo() { P0=P1=P2=P3=0xff; for(x=0;x<=8;x++) { P2=P1=0x00; delay(2000); P2=P1=0xff; P0=P3=0x00; delay(2000); P0=P3=0xff; } } void da_hai() { for(x=0;x<=8;x++) { P0=P1=P2=P3=0x55; delay(2000); P0=P1=P2=P3=0xaa; delay(2000); } } void nhap_nhay() { for(x=0;x<=8;x++) { P0=P1=P2=P3=0x00; delay(2000); P0=P1=P2=P3=0xff; delay(2000); } } void main() { while(1) { sang_dan(); nhap_nhay(); toi_dan(); nhap_nhay(); sang_2ben(); nhap_nhay(); kieu_4() ; nhap_nhay(); kieu_5() ; nhap_nhay(); kieu_6() ; nhap_nhay(); nhap_nhay_nua(); nhap_nhay(); da_hai(); toi_dan_1_led(); nhap_nhay(); da_hai(); nhap_nhay_nua_cheo(); nhap_nhay(); } }
Nguyên văn bởi tdm Xem bài viếtcode:
bác cho e xin yahoo đy bác
Gmail:
Trả lời cho Có ai biết ....bởi nhathung1101Lão này sắp hại tôi rồi!!!
Vừa mất time đi phúng, lại còn toi cái phong bì....-
24-08-2025, 19:59 -
Trả lời cho Giúp về vấn đề đảo chiều động cơbởi nguyendinhvanCái này áp dụng vào xe đạp điện thì ok. Chỉ cần quay 1 chiều.
Khi người sử dụng đạp một vòng, mạch sẽ nhận dạng vòng quay bánh xe, cấp điện cho động cơ quay bánh xe ổn định, liên tục đúng bằng tốc độ vòng quay mà người sử...-
24-08-2025, 12:47 -
Trả lời cho Có ai biết ....bởi tuyennhanMa sát rồi còn bảo toàn năng lượng nữa đâu chỉ tính hiệu suất là chưa đủ , có cái chữ thêm vào là ổn ngay dù có bao nhiêu công đoạn đi nữa .
Đố bác biết chữ gì .-
24-08-2025, 08:16 -
Trả lời cho Có ai biết ....bởi nguyendinhvanCũng có thể sai. Nếu mỗi cái hiệu suất 95%, thì đến chỗ nào là nó không hoạt động được nữa ?
23-08-2025, 20:25 -
