Nguyên văn bởi ->TVXQ<-
các bác giúp sửa hộ e cái ct với help????
Gmail:
Nguyên văn bởi tdm Xem bài viếtcode:
Code:#include"reg52.h" char x,y,i,j,q,tong1; int tong2; const unsigned char ma_led[6][8]={ 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,//sang dan lsb..msb 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,//sang dan msb..lsb 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xff,//toi dan lsb..msb 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,//toi dan msb.lsb 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,//toi dan 1 led lsb...msb 0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//toi dan 1 led msb...lsb void delay(unsigned long int t) { unsigned long int l; for(l=0;l<t;l++); } void sang_dan() { P0=P1=P2=P3=0xff; for(x=0;x<=7;x++) { P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P3=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[1][x]; delay(2000); } for(x=0;x<=7;x++) { P0=ma_led[1][x]; delay(2000); } } void toi_dan() { P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P1=ma_led[2][x]; delay(2000); } for(x=0;x<=7;x++) { P3=ma_led[2][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[3][x]; delay(2000); } for(x=0;x<=7;x++) { P0=ma_led[3][x]; delay(2000); } } void toi_dan_1_led() { P0=P1=P2=P3=0x00; delay(2000); for(x=0;x<=7;x++) { P1=ma_led[4][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P3=ma_led[4][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P2=ma_led[5][x]; delay(2000); } P0=P1=P2=P3=0x00; for(x=0;x<=7;x++) { P0=ma_led[5][x]; delay(2000); } P0=P1=P2=P3=0x00; } void sang_2ben() { P0=P1=P2=P3=0xff; for(x=0;x<=7;x++) { P0=ma_led[0][x]; P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[0][x]; P3=ma_led[0][x]; delay(2000); } } void kieu_4() { for(x=0;x<=7;x++) { P0=ma_led[0][x]; P1=ma_led[0][x]; delay(2000); } for(x=0;x<=7;x++) { P2=ma_led[1][x]; P3=ma_led[1][x]; delay(2000); } } void kieu_5() { for(x=0;x<=7;x++) { P1=ma_led[0][x]; P3=ma_led[1][x]; P0=ma_led[0][x]; P2=ma_led[1][x]; delay(2000); } } void kieu_6() { for(x=0;x<=7;x++) { P0=ma_led[2][x]; P1=ma_led[2][x]; P2=ma_led[3][x]; P3=ma_led[3][x]; delay(2000); } } void nhap_nhay_nua() { P0=P1=P2=P3=0xff; for(x=0;x<=8;x++) { P0=P2=0x00; delay(2000); P0=P2=0xff; P1=P3=0x00; delay(2000); P1=P3=0xff; } } void nhap_nhay_nua_cheo() { P0=P1=P2=P3=0xff; for(x=0;x<=8;x++) { P2=P1=0x00; delay(2000); P2=P1=0xff; P0=P3=0x00; delay(2000); P0=P3=0xff; } } void da_hai() { for(x=0;x<=8;x++) { P0=P1=P2=P3=0x55; delay(2000); P0=P1=P2=P3=0xaa; delay(2000); } } void nhap_nhay() { for(x=0;x<=8;x++) { P0=P1=P2=P3=0x00; delay(2000); P0=P1=P2=P3=0xff; delay(2000); } } void main() { while(1) { sang_dan(); nhap_nhay(); toi_dan(); nhap_nhay(); sang_2ben(); nhap_nhay(); kieu_4() ; nhap_nhay(); kieu_5() ; nhap_nhay(); kieu_6() ; nhap_nhay(); nhap_nhay_nua(); nhap_nhay(); da_hai(); toi_dan_1_led(); nhap_nhay(); da_hai(); nhap_nhay_nua_cheo(); nhap_nhay(); } }
good luck!!!!!
Gmail:
AK MÀ ĐÂY HUM NAY MỚI TÌM THẤY LINK BÁC NÀO LÀM CHƯA NHỈ.CÁI NÀY 89C51 CÓ LÀM ĐC K CÁC BÁC.MÀ CHỈ CẦN MẤY CÁI HIỆU ỨNG NHƯ I LOVE U THÔI VỚI LẠI CÁI MẮT NHÁY NHÁY Ý CÁC BÁC NHÌN ĐẸP GHÊ.E CŨNG ĐANG CÓ MẤY CÁI MATRIX ĐANG MUỐN LÀM CÁI KIỂU NÀY BÁC NÀO PÍT CHỈ GIÚP E VỚI NHA.THANK NHÌU NHÌU AK.
GOOD LUCK !!!
Gmail:
Nguyên văn bởi tuankep6 Xem bài viếtAK MÀ ĐÂY HUM NAY MỚI TÌM THẤY LINK BÁC NÀO LÀM CHƯA NHỈ.CÁI NÀY 89C51 CÓ LÀM ĐC K CÁC BÁC.MÀ CHỈ CẦN MẤY CÁI HIỆU ỨNG NHƯ I LOVE U THÔI VỚI LẠI CÁI MẮT NHÁY NHÁY Ý CÁC BÁC NHÌN ĐẸP GHÊ.E CŨNG ĐANG CÓ MẤY CÁI MATRIX ĐANG MUỐN LÀM CÁI KIỂU NÀY BÁC NÀO PÍT CHỈ GIÚP E VỚI NHA.THANK NHÌU NHÌU AK.
GOOD LUCK !!!
chào các bác ai cho e hỏi e đang có mấy con 89s52 muốn làm 1 cái trái tim nữa mà thấy mấy cái này ít hiệu ứng quá với lại hình như k có hiệu ứng sao băng thì phải vậy ai có cái code nào full hiệu ứng dùng cho 89s52 thì cho e xin với ak tầm trên 30 hiệu ứng đc k ak miễn là full ai có cho e xon với nha vì con này có 8k nên viết có mấy hiệu ứng thì phí quá đi mất mà cũng trên 1 con e nghĩ làm đc càng nhiều hiệu ứng càng tốt C hay asm đều đc nhưng nếu = asm thì e còn chỉnh sửa đc chút nếu nó chạy nhanh quáthank các bác nhiều nha
giúp e với nha
17-02-2025, 14:40 -
17-02-2025, 06:08 -
Rồi xem.-
17-02-2025, 01:38 -
Tốt nhất im mồm....-
17-02-2025, 01:26 -
14-02-2025, 16:15 -
1 step down
2 step up
Tính chất là:
2 Đầu vào cao hơn...-
14-02-2025, 00:51 -
Nó là mạch ổn dòng.
14-02-2025, 00:42 -
13-02-2025, 17:02 -
13-02-2025, 08:43 -
13-02-2025, 07:39 -
