Mong các bác giúp em sửa cái code này
  • Mong các bác giúp em sửa cái code này
    Em làm đề tài đo nhiệt độ có cái code này dùng keil c dịch nó báo lỗi sửa mãi không được đây là code của em.các bác xem rồi sửa giùm em với
    #include"imt_reg51.h"
    #include"intrins.h"
    #include"delay.h"
    #include"port_init.h"
    #include"lcd.h"
    void main()
    unsigned char value_T;
    port_init();
    LCD_ON_OFF = LCD_ON;
    lcd_init();
    while(1)
    //TEMPERATURE SENSOR
    lcd_gotoxy(0,0);
    lcd_printf("T: C");
    lcd_cmd_wr(0x84);
    lcd_data_wr(0xdf);
    ADC_CH0=0;
    ADC_CH1=0;
    ADC_CH2=0;
    ADC_ALE=0;
    ADC_SOC=0;
    ADC_OE=0;
    value_T=hex_dec(start_conv());
    T=hex_dec(value_T+0x02);
    lcd_cmd_wr(0x82);
    lcd_print(T);
    void port_init(void)
    P0 = 0xFF; // Port0 initialized as input port
    P1 = 0xFF; // Port1 initialized as input port
    P2 = 0xFF; // Port2 initialized as input port
    P3 = 0xFF; // Port3 initialized as input port
    void lcd_init(void)
    uchar i;
    uchar lcd_initseq[4] =
    MODE6, // Interface datalength=8, display lines=2, character font=5*7 dots.
    DISP_ON_CU_OFF, // Display ON and Cursor OFF
    CLR_DISP // Write space code to all DDRAM, set AC to 0 and set for Cursor Increment mode.
    delay_msec(5);
    for(i = 0;i < 4;i++)
    lcd_cmd_wr(lcd_initseq[i]); // LCD command write module
    void lcd_cmd_wr(uchar lcd_cmd)
    wait_lcd(); // wait until lcd is busy
    DATA_BUS = lcd_cmd; // place lcd command value on the data bus
    LCD_RS = LCD_CMD_REG; // Select command register for storing command value
    LCD_RW = LCD_WRITE; // select write operation mode to write comand value into command register
    ADD_BUS = LCD_ADD; // enable lcd to read command value available on data bus and store into command register
    delay_msec(1);
    ADD_BUS = DISABLE; // disable all peripherl device
    void lcd_data_wr(uchar lcd_data)
    DATA_BUS = lcd_data; // place data value on data bus which is to be written into lcd.
    LCD_RS = LCD_DATA_REG; // select lcd data register to store data value
    LCD_RW = LCD_WRITE; // select write operation mode for writing data value into lcd data register
    ADD_BUS = LCD_ADD; // enable lcd to read data value available on the data bus
    delay_msec(1);
    ADD_BUS = DISABLE; //disable all peripheral devices
    bit lcd_gotoxy(unsigned char x, unsigned char y)
    unsigned char xy;
    bit flag = 0;
    y = (y == 0)?(0x80)y == 1)?(0XC0)0X00)); // Assign LCD column Address to y coordinate
    x = ((x >= 0)||(x <= 15))?x:0x00; // Assign LCD Row Address to X coordinate
    xy = x + y; // XY coordinate Address
    if(xy)
    lcd_cmd_wr(xy); // If Valid Address Move cursor to LCD xy coordinate
    flag = 1;
    return(flag);
    void wait_lcd()
    LCD_BF = 1; // set D7 data line as input line to read busy flag
    DATA_BUS = INPUT_PORT;
    LCD_RS = LCD_CMD_REG; //select lcd command register to read busy flag
    LCD_RW = LCD_READ; // select read operation to read busy flag from lcd
    ADD_BUS = LCD_ADD; // enable lcd to read busy flag
    delay_msec(1);
    while(LCD_BF) // check continuously until lcd is busy
    ADD_BUS = DISABLE; // disble all peripheral device including lcd.
    unsigned char start_conv()
    unsigned char C;
    P0=0xff;
    P2=0xff;
    ADC_ALE=1; //ADC_ALE//
    delay_msec(1);
    ADC_SOC=1; //ADC_SOC//
    delay_msec(1);
    ADC_ALE=0; //ADC_ALE//
    delay_msec(1);
    ADC_SOC=0; //ADC_SOC
    delay_msec(1);
    while(ADC_EOC==0);
    ADC_OE=1; //ADC_OE
    P0=0x22;
    C=P2;
    delay_msec(1);
    ADC_OE=0;
    P0=0xff; //ADC_OE
    return(C);
    unsigned char hex_dec(unsigned char D)
    unsigned char LB,HB,temp,count,AX;
    temp=D;
    temp=_crol_((0xf0&temp),4);
    for(HB=0x00,count=0x00;count<temp;count++)
    HB=HB+0x16;
    AX=AC;
    if(AX==1)
    HB=HB+0X06;
    if((HB&0X0F)>0X09&&(HB&0XF0)>0X90)
    HB=HB+0X66;
    else if((HB&0X0F)>0X09)
    HB=HB+0X06;
    else if((HB&0XF0)>0X90)
    HB=HB+0X60;
    else
    HB=HB;
    LB=D&0x0F;
    HB=HB+LB;
    cảm ơn các bác
    AX=AC;
    if(AX==1)
    HB=HB+0X06;
    HB=HB+0X66;
    HB=HB+0X06;
    HB=HB+0X60;
    else
    HB=HB;
    return(HB);
    tui có thấy Keil C báo lỗi j đâu , lỗi j thì u copy , up lên đây thì mới biết mà chữa đc chứ
      Cái biến T trong hàm main chưa khai báo kìa.
      believe4me Tìm hiểu thêm về believe4me
        23-02-2025, 07:44
        23-02-2025, 02:00
        22-02-2025, 22:18
        22-02-2025, 14:51
        22-02-2025, 14:39
        22-02-2025, 14:28
