32ledTRÁI TIM dùng ic89c51 cho dân điện tử
Nguyên văn bởi boychjpcoj Xem bài viếtai có chtrình sáng dồn 32led trái tim ko. sáng từng led 1 sau đó giữ led nah.
good luck
Gmail:
Code:#include"reg51.h" char x,y,i,j,q,g=0x00; int tong2; unsigned long int time=2000;//thay đổi giá trị time để có delay mong muốn void sang_don(); void don_32(); void don_24(); void don_16(); void don_8(); const unsigned char ma_led[]= {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x81,0x82,0x84,0x88,0x90, 0xA0,0xC0,0xC1,0xC2,0xC4,0xC8,0xD0,0xE0,0xE1,0xE2,0xE4,0xE8,0xF0,0xF1,0xF2,0xF4,0xF8,0xF9,0xFA, 0xFC,0xFD,0xFE,0xff}; unsigned long tam; void delay(unsigned long int t) { unsigned long int l; for(l=0;l<t;l++); } main() { while(1) { g=0; don_32(); g++; don_24(); g++; don_16(); g++; don_8(); delay(time+1000); P1=P2=P3=P0=0xff; } } void sang_don() { for(x=0;x<=j;x++) { switch (y) { case 0: { if(g==0) P0=~ma_led[0+x]; else if(g==1) P2=~ma_led[0+x]; else if(g==2) P3=~ma_led[0+x]; else if(g==3) P1=~ma_led[0+x]; break; } case 1: { if(g==0) P0=~ma_led[8+x]; else if(g==1) P2=~ma_led[8+x]; else if(g==2) P3=~ma_led[8+x]; else if(g==3) P1=~ma_led[8+x]; break; } case 2: { if(g==0) P0=~ma_led[15+x]; else if(g==1) P2=~ma_led[15+x]; else if(g==2) P3=~ma_led[15+x]; else if(g==3) P1=~ma_led[15+x]; break; } case 3: { if(g==0) P0=~ma_led[21+x]; else if(g==1) P2=~ma_led[21+x]; else if(g==2) P3=~ma_led[21+x]; else if(g==3) P1=~ma_led[21+x]; break; } case 4: { if(g==0) P0=~ma_led[26+x]; else if(g==1) P2=~ma_led[26+x]; else if(g==2) P3=~ma_led[26+x]; else if(g==3) P1=~ma_led[26+x]; break; } case 5: { if(g==0) P0=~ma_led[30+x]; else if(g==1) P2=~ma_led[30+x]; else if(g==2) P3=~ma_led[30+x]; else if(g==3) P1=~ma_led[30+x]; break; } case 6: { if(g==0) P0=~ma_led[33+x]; else if(g==1) P2=~ma_led[33+x]; else if(g==2) P3=~ma_led[33+x]; else if(g==3) P1=~ma_led[33+x]; break; } case 7: { if(g==0) P0=~ma_led[35+x]; else if(g==1) P2=~ma_led[35+x]; else if(g==2) P3=~ma_led[35+x]; else if(g==3) P1=~ma_led[35+x]; break; } } delay (time); } j--; } void don_32() { j=7; for(y=0;y<=7;y++) { for(q=0;q<=2;q++) { for(x=0;x<=7;x++) { switch (q) { case 0: { P1= ~ma_led[x]; delay (time); break; } case 1: { P3= ~ma_led[x]; delay (time); break; } case 2: { P2= ~ma_led[x]; delay (time); break; } } } P2= P1= P3=0xff; } sang_don(); } } void don_24() { j=7; for(y=0;y<=7;y++) { for(q=0;q<=1;q++) { for(x=0;x<=7;x++) { switch (q) { case 0: { P1= ~ma_led[x]; delay (time); break; } case 1: { P3= ~ma_led[x]; delay (time); break; } } } P1= P3=0xff; } sang_don(); } } void don_16() { j=7; for(y=0;y<=7;y++) { for(x=0;x<=7;x++) { P1= ~ma_led[x]; delay (time); } P1=0xff; sang_don(); } } void don_8() { j=7; for(y=0;y<=7;y++) { sang_don(); } }
Attached Files|
Nguyên văn bởi tdm Xem bài viếtthử cái này xem sao:
vừa mới học asm thui
bác có bản asm k e mới viết 16 led thôi chưa viết 32 led để tẹo rảnh viêt cái xem sao
Gmail:
Nguyên văn bởi tdm Xem bài viếtđã mô phỏng thử chưa mà biết nó tắt dần.
Nguyên văn bởi boychjpcoj Xem bài viếtmô phỏng rồi mà.không phải tắt dần mà là tắt dồn. điều khiển âm ah. thế làm sao sửa diều khiển dương?
Nguyên văn bởi ckd_speed Xem bài viếtMạch của bạn điều khiển dương mà sáng được cũng hay thật đấy
Hôm qua, 21:31 -
Hôm qua, 11:52 -
19-02-2025, 21:27 -
19-02-2025, 21:24 -
- Tôi cũng có vợ như thế....
19-02-2025, 21:04 -
17-02-2025, 06:08 -
17-02-2025, 01:38 -
