anh em giúp với?
viết code keil sáng dồn
PHP Code:unsigned char trai_sang(char i)
unsigned char bang_2[]={0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00};
return bang_2[i];
void kieu_2()
char j=0;
P1=P2=P3=P0=0xFF;
for(j=0;j<8;j++)
P1=trai_sang(j);
delay(150);
for(j=0;j<8;j++)
P3=trai_sang(j);
delay(150);
for(j=0;j<8;j++)
P2=trai_sang(j);
delay(150);
for(j=0;j<8;j++)
P0=trai_sang(j);
delay(150);
void main()
while(1)
kieu_2();
16-11-2024, 15:34 -
16-11-2024, 10:39 -
15-11-2024, 08:27 -
10-11-2024, 08:52 -
10-11-2024, 08:47 -
09-11-2024, 13:36 -
09-11-2024, 12:55 -
