SDcard va MMCard voi 8051
file Fat32.h
// File: fat32.h
// Description: MCS51 C module for FAT32 layer on Memory Card, v 1.0408
// Author: PHAM ANH SAO <saobui@gmail.com>
// Compiler: Keil uVision
// Date: March 30, 2008
#ifndef _FAT32_H_
#define _FAT32_H_
#define FAT32_OPTIMIZE_CODE
#ifdef _WRITE_SUPPORT
#define FAT32_WRITE_SUPPORT
#endif
// Errors
#define FAT32_ERROR_INIT -1
#define FAT32_NO_ERROR 0
#define FAT32_ERROR_IO 1
#define FAT32_ERROR_FORMAT 2
// File Type Difinition
typedef char fat32File;
// Max number of concurrent files
#define HANDLE_MAX 10
// File Attributes
#define FAT32_FILE_ATTR_READ_ONLY 0x01 // Read Only
#define FAT32_FILE_ATTR_HIDDEN 0x02 // Hidden
#define FAT32_FILE_ATTR_SYSTEM 0x04 // System
#define FAT32_FILE_ATTR_VOLUME_ID 0x08 // Volume ID
#define FAT32_FILE_ATTR_DIRECTORY 0x10 // Directory
#define FAT32_FILE_ATTR_ARCHIVE 0x20 // Archive
#define FAT32_FILE_ATTR_LONG_NAME 0x0F // Long Name
// Function Prototypes
extern char fat32Init(void);
#ifdef FAT32_WRITE_SUPPORT
extern fat32File fat32FileOpen(const char *Path, char Mode);
extern int fat32FileWrite(fat32File Handle, char *BufferOut, unsigned int NoBytes);
extern char fat32FileUnlink(const char *Path);
#else
extern fat32File fat32FileOpen(const char *Path);
#endif // FAT32_WRITE_SUPPORT
extern char fat32FileClose(fat32File Handle);
extern long fat32FileLSeek(fat32File Handle, unsigned long Offset, char FromWhere);
extern unsigned long fat32FileSize(fat32File Handle);
extern int fat32FileRead(fat32File Handle, char *BufferIn, unsigned int NoBytes);
extern char fat32FileEnd(fat32File Handle);
#ifndef FAT32_OPTIMIZE_CODE
extern char fat32FileSetPos(fat32File Handle, unsigned long Pos);
#else
#define fat32FileSetPos(Handle, Pos) fat32FileLSeek(Handle, Pos, SEEK_SET)
#endif // FAT32_OPTIMIZE_CODE
// Definitions and Macros to use functions as ANSI C
// Modes used in Accessing files
#define O_RONLY 0x01
#define O_WONLY 0x02
#define O_RDWR 0x03
#define O_APPEND 0x04
#define O_CREATE 0x08
#define O_EXCL 0x10
#define O_TRUNC 0x20
#define O_TEXT 0x40
#define O_BINARY 0x80
// Attributes
#define FA_RONLY FAT32_FILE_ATTR_READ_ONLY
#define FA_HIDDEN FAT32_FILE_ATTR_HIDDEN
#define FA_SYSTEM FAT32_FILE_ATTR_SYSTEM
#define FA_LABEL FAT32_FILE_ATTR_VOLUME_ID
#define FA_DIREC FAT32_FILE_ATTR_DIRECTORY
#define FA_ARCH FAT32_FILE_ATTR_ARCHIVE
#define FA_LNAME FAT32_FILE_ATTR_LONG_NAME
// SEEKs
#define SEEK_SET 0
#define SEEK_CUR 1
#define SEEK_END 2
// Macros
#define open(path, mode) fat32FileOpen(path, mode)
#define write(handle, buff, len) fat32FileWrite(handle, buff, len)
#define unlink(path) fat32FileUnlink(path)
#define setattr(path, attr) fat32FileSetAttribute(path, attr) // Not ANSI C
#else
#define open(path, mode) fat32FileOpen(path)
#define close(handle) fat32FileClose(handle)
#define read(handle, buff, len) fat32FileRead(handle, buff, len)
#define lseek(handle, offset, fromwhere) fat32FileLSeek(handle, offset, fromwhere)
#define eof(handle) fat32FileEnd(handle) // Not ANSI C
#define sizef(handle) fat32FileSize(handle) // Not ANSI C
#endif // _FAT32_H_
File mc.h
// File: mc.h
// Description: C module for Memory Card (MMC/SD) physical operations
// Date: March 15, 2008
#ifndef _MC_H_
#define _MC_H_
#define MC_OPTIMIZE_CODE
#define MC_WRITE_SUPPORT
#endif
// Errors
#define MC_TRUE 1
#define MC_FALSE 0
#define MC_NO_ERROR 0x00
#define MC_ERROR_IO 0x02
#define MC_ERROR_TIME_OUT 0x54
// MC Types
#define MC_TYPE_MMC 1
#define MC_TYPE_SD 0
// Constants
#define MC_BLOCK_LEN 512
// Global Function Prototypes for Memory Card Layer
// If Code is Prefered some functions may be macros, or not available
extern char mcInitCard(void);
extern char mcSetBlockSize(unsigned int NoBytes);
extern char mcReadBlockPart(unsigned long Address, char *BufferIn,
unsigned int Start, unsigned int Size);
#ifdef MC_WRITE_SUPPORT
extern char mcWriteBlockPart(unsigned long Address, char *BufferIn,
#ifndef MC_OPTIMIZE_CODE
extern char mcWriteBlock(unsigned long Address, const char *BufferOut);
#else // MC_OPTIMIZE_CODE
#define mcWriteBlock(Blk, Bufo) mcWriteBlockPart(Blk, Bufo, 0, MC_BLOCK_LEN)
#endif // MC_OPTIMIZE_CODE
#endif // MC_WRITE_SUPPORT
extern char xdata mcCSD[18]; // Card Specific Data Register (16 bytes+ CRC16)
extern char xdata mcOCR[4]; // Operating Control Register
extern char xdata mcCID[18]; // Card Identification Register (16 bytes+ CRC16)
extern char mcReadCSD(void);
extern char mcWriteCSD(void);
extern char mcReadCID(void);
extern char mcReadOCR(void);
extern char mcReadBlock(unsigned long Address, char *BufferIn);
#define mcReadBlock(Blk, Bufi) mcReadBlockPart(Blk, Bufi, 0, MC_BLOCK_LEN)
#endif // _MC_H_
File rs232.h
// File: rs232.h
// Description: C module for RS-232 communication on MCS-51
// Date: March 23, 2008
#ifndef _RS232_H_
#define _RS232_H_
#include <reg52.h>
extern void rs232Init(char asVoid); // Data: 1-8-1, No Parity, 9600 @ 24M
extern void rs232SendByte(char Sent);
extern char rs232ReceiveByte(unsigned char TimeOut);
extern void rs232SendString(const char *String);
extern void rs232SendBytes(unsigned int NoBytes, const char *Bytes);
extern void rs232ReceiveLine(char *LineBuf);
#ifndef __STDIO_H__
#define puts(s) rs232SendString(s)
#define gets(s) rs232ReceiveLine(s)
#define getch() rs232ReceiveByte(0xFF)
#define putch(c) rs232SendByte(c)
#endif // __STDIO_H__
#endif // _RS232_H_
File mcTest.c
//#define _WRITE_SUPPORT
#include "rs232.h"
#include "fat32.h"
#include <reg52.h>
sbit LED_MCIN= P1^7; // Memory Card Insert LED
sbit MCOUT= P3^2; // Memory Card Out
#define MCIN !MCOUT
void Timer0(void);
char xdata mcInserted;
void main()
char xdata mcBuffer[2050];
char xdata Path[256];
unsigned int len;
fat32File file;
// Init Serial Port
rs232Init(0);
rs232SendString(" MEMORY CARD TEST by PHAM ANH SAO\n");
// Init Timer 0
TMOD|= 0x02; // Timer0, 8 bit auto load
TH0= 0x00; // auto load value
IE|= 0x82;
TR0= 1; // Start Timer0
// Init FAT32 for Memory Card
while(fat32Init()!= 0)
rs232SendString("> FAT32 Initialization Error!\n");
// Open a sample file and display its contents
while(1)
rs232SendString("> Type the File Path to Open...\n> ");
rs232ReceiveLine(Path);
// Open a file for Read and Write (O_RDWR)
// and set file pointer to end of file (O_APPEND)
// If file does not exist, we create it (O_CREATE)
if((file= open(Path, O_CREATE| O_RDWR| O_APPEND))!= -1)
rs232SendString("> File Opened!\n");
// Write a sample string to file
if(write(file, "<saobui@gmail.com>", 21)== -1)
rs232SendString("\n> Write Fail!\n");
else
rs232SendString("\n> Data Successfully Written to File!\n");
#endif
// Rewind the file
lseek(file, 0, SEEK_SET);
// Display contents
while(!eof(file))
len= read(file, mcBuffer, 2048);
rs232SendBytes(len, mcBuffer);
// Close file
if(close(file)== 0)
rs232SendString("\n> File Now Closed!\n");
else
rs232SendString("> File Could Not be Opened!\n");
void Timer0() interrupt 1 using 1
TR0= 0;
if(MCIN)
LED_MCIN= 1;
if(!mcInserted)
rs232SendString("\n> Card Inserted!\n");
mcInserted= 1;
else
LED_MCIN= 0;
if(mcInserted)
rs232SendString("\n> Card Removed! \n");
mcInserted= 0;
TR0= 1;
tôi gửi cả 4 fi le đó, các bạn xem. tôi đã chuyển File mcTest.c sang File.Hex mà cứ báo lỗi là sao nhỉ, có phai do tôi thiếu thư viện File hỗ trợ không, ai có hi cho tôi , hoặc chỉ ra thất bại của tôi ở đâu nhé
Giao tiếp thẻ nhớ MMC & SD Card - Quang bao, led, ty gia vang
tôi đã xem qua link này nhưng không biết ghép chô nào với nhau nữa, giúp tôi với cả DIỄN ĐÀN ơi
Nguyên văn bởi bvhoang Xem bài viếtLại một đồng chí lấy thư viện FAT32 của mình và sửa tên tác giả thành của họ. Rất may mà mình chưa post source thư viện lên...
bởi nguyendinhvanTại sao nó lại có cơ sở dữ liệu như thế này.
Ciệc kiếm một danh sách điện thoại dể quảng cáo ,tiếp thị, thậm chí là cả việc xấu hoàn toàn dễ dàng.
Channel: Công nghệ internet và mạng có dây
Hôm qua, 22:26 -
Hôm qua, 08:30 -
Hôm qua, 07:21 -
Hôm qua, 07:02 -
bởi vi van phamNhắn tin khẩn:
Hôm qua, 05:57 -
26-04-2025, 23:16 -
26-04-2025, 21:33 -
26-04-2025, 20:52 -
Trả lời cho Tổng hợp quạt điện : điện tử , Cơ , phun sươngbởi Nikon57Mình có cái quạt trần điện cơ, xông điện vào không chạy . Dỡ xuống tháo ra quan sát thấy một đầu dây trong một bối dây bị đứt thò ra goài. Quạt cố, cả cuộn làm việc và cuồn đề bố trí thành một vòng . Xin xem ảnh kèm theo. Đo trở...
26-04-2025, 15:09 -
Trả lời cho Xin hỏi về chiết ápbởi mèomướpDạ cháu hông có tiền để mua điện thoại riêng chơi mạng xã hội đâu ạ. Chú có điều kiện thì tài trợ cho cháu cái ai phôn 16 pờ rồ mắc để cháu học dùng facebook rồi kết bạn với chú ạ...
26-04-2025, 13:14 -
