giúp mình khắc phục lỗi "access violation"
  • giúp mình khắc phục lỗi "access violation"
    mình có đoạn code để capture từ video (1) hoặc từ camera(2). nhưng khi mình chọn từ video và nhập vào địa chỉ file.avi thì luôn bị lỗi "Unhandled exception at 0x00905a4d in demo.exe: 0xC0000005: Access violation."
    int main(int argc, TCHAR* argv[])//MainProgram
    int b=0,a=0,d=0;
    CvCapture* capture;
    int input=0,bfv = 0,counter = 0;
    double mean=10;
    double area1 = 0;
    cout<<"Please specify input\nvideo(1) or webcam(2)?";
    cin>> input;
    if (input == 1)
    char filename[255];
    memset(filename,0,255);
    cout<<"Please key in the adress to the video\n";
    cin>>filename;
    capture = cvCreateFileCapture( filename );
    if (input == 2)
    capture =cvCreateCameraCapture(0);
    IplImage* start;
    start = cvQueryFrame(capture);
    for (int counter =0;counter<30;counter ++)
    frame [counter] = NULL;
    frameG [counter] = NULL;
    frame2 [counter] = NULL;
    frame2G [counter] = NULL;
    frame3 [counter] = NULL;
    frame3G [counter] = NULL;
    while(1)
    if(storage==NULL)storage = cvCreateMemStorage(0);
    frame[a] = cvQueryFrame( capture );
    IplImage* _img= cvQueryFrame( capture );
    if(_img==NULL)break;
    frame[a]= cvCreateImage(cvGetSize(_img),_img->depth,_img->nChannels);
    frameG[a]=cvCreateImage(cvGetSize(_img),8,1);
    frame2[a]=cvCreateImage(cvGetSize(_img),_img->depth,_img->nChannels);
    frame2G[a]=cvCreateImage(cvGetSize(_img),8,1);
    frame3[a]=cvCreateImage(cvGetSize(_img),_img->depth,_img->nChannels);
    frame3G[a]=cvCreateImage(cvGetSize(_img),8,1);
    cvCopy(_img,frame[a]);
    if( !frame ) break;
    char c = cvWaitKey(33);
    if( c == 27 ) break;
    cvCvtColor(frame[a], frameG[a], CV_BGR2GRAY);
    CvScalar avg = cvAvg(frameG[a]);
    cout<< avg.val[0]<< "\n";
    if (avg.val[0] < 2)
    mean=(avg.val[0]/0.015);
    else if ((avg.val[0]>=2) && (avg.val[0] <= 70))
    mean=(avg.val[0]/1.5);
    else
    mean =(avg.val[0]/5);
    if(frame[29])
    cvReleaseImage(&frame[29]);
    if(frameG[29])
    cvReleaseImage(&frameG[29]);
    if(frame2[29])
    cvReleaseImage(&frame2[29]);
    if(frame2G[29])
    cvReleaseImage(&frame2G[29]);
    if(frame3[29])
    cvReleaseImage(&frame3[29]);
    if(frame3G[29])
    cvReleaseImage(&frame3G[29]);
    for ( int counter2=29;counter2>(0);counter2--)
    frame[counter2]= frame [(counter2-1)];
    frameG[counter2] = frameG [(counter2-1)];
    frame2[counter2]= frame2 [(counter2-1)];
    frame2G[counter2] = frame2G [(counter2-1)];
    frame3[counter2]= frame3 [(counter2-1)];
    frame3G[counter2]= frame3G [(counter2-1)];
    bfv++;
    a=0;
    b=15;
    if ( bfv >=30)
    cvSub(frame[b],frame[a],frame2[a]);
    cvSub(frame[d],frame[a],frame3[a]);
    cvCvtColor(frame2[a],frame2G[a],CV_BGR2GRAY);
    cvThreshold(frame2G[a],frame3G[a],mean,255,CV_THRESH_BINARY);
    cvSmooth(frame3G[a],frame3G[a],CV_MEDIAN,9,9);
    cvDilate(frame3G[a],frame3G[a],NULL,5);
    cvErode(frame3G[a],frame3G[a],NULL,6);
    cvFindContours(frame3G[a],storage,&contour,sizeof(CvContour),CV_RETR_CCOMP, CV_CHAIN_APPROX_SIMPLE );
    IplImage*frameb = frame[15];
    IplImage*framec = frame[16];
    contourprocess(frameb,framec,contour,area1);
    if (contour!=NULL)
    { cvClearSeq(contour);
    cvClearMemStorage(storage);
    printf("End of File\n");
    cvReleaseMemStorage(&storage);
    cvReleaseCapture( &capture );
    //cvDestroyWindow( "FireDetect" );
    cvDestroyAllWindows();
    fclose(fp);
    return 0;
    Theo hiểu biết mà như ít bao giờ chính xác của mình là có cái j đó sai trong lệnh của bạn!
    Thông thường những lỗi đó là: bạn thử dùng cái này đế load trực tiếp thử, ví dụ như "E:/Picture/Symbol.jpg", nhớ là "/" chứ không phải là "\", C++ nó khó lắm, nếu sai cái này thì nó cũng "break" luôn, bạn có thể lấy cái file đó nhét vào trong chương trình thì load ra ko cần đường dẫn, chỉ cần gọi "symbol.jpg", chương trình của bạn là xử lý các frame camera bằng các thuật toán đơn giản, nhưng mình thấy phức tạp quá, bạn thử nói ý tưởng bạn làm gì với 2 cái camera đấy, biết đâu mình làm rồi gởi cho bạn luôn!
    star174 Tìm hiểu thêm về star174
