Cài đặt nhân để lập trình nhúng như thế nào?với snapgear
  • Cài đặt nhân để lập trình nhúng như thế nào?với snapgear
    Em định cài đặp nhân cho lập trình nhúng, đọc bài của bác Thanh thấy cài realtime linux + với nhân, ví dụ em muốn cài nhân linux để lập trình nhúng và em thấy thằng snapgear.org có hỗ trợ con IXP425
    http://www.snapgear.org/snapgear/downloads.html
    Downloads
    Links below point to the SnapGear Embedded Linux Distribution. SnapGear Linux is a full source package, containing kernel, libraries and application code for rapid development of embedded Linux systems.
    Source
    The following link is the latest snapshot source package that includes support for a wide variety of CPU architectures. It contains support for X86, M68k, ColdFire, ARM/XSCALE, Hitachi SuperH and many other microprocessor architectures, on many varied target platforms. It also contains 2.0.39, 2.4.32 and 2.6.19 Linux kernel sources, uC-libc, newer uClibc-0.9.27 libraries and a huge collection of application packages - everything you need to build fully functional embedded Linux systems.
    SnapGear Embedded Linux (3.5.0) [tarred gzipped]
    This is a source only package. You will need a tool chain to generate anything useful from this source. Several pre-built binary tools packages are available.
    Also available is a patch package that can be used to build the Intel IXP4xx Access Library code as part of the SnapGear distribution. This patch set contains support for the Intel CSR-1.4 with DSR-2.6.2 combination, and the Intel CSR-2.4 library (on both 2.4 and 2.6 linux kernels).
    SnapGear IXP400 Access Library patch [shar]
    Tools
    uClinux Tool Chains:
    * M68k/ColdFire - m68k-uclinux-tools-20061214.sh binary and source
    * ARM - arm-linux-tools-20061213.tar.gz binary and source
    * SPARC - sparc-elf-20020214.tar.gz binary and source
    * H8300 - h8300-elf-20030420.tar.gz binary and source
    Linux Tool Chains:
    * x86 - i386-linux-20030930.tar.gz binary and source
    * ARM/XSCALE - arm-linux-tools-20061213.tar.gz binary and source
    * SuperH - sh-linux-20021008.tar.gz binary (sh-linux-tools-20021008-g++-v3.tar.gz g++ headers) and source
    Generally speaking the tool chains consists of at least the following packages:
    * binutils, gcc, gdb (from www.gnu.org)
    Some targets also require additional tools for generating FLAT format binaries (uClinux targets), filesystem creation tools (genromfs, genext2fs, etc) or checksumming utilities. Original source, patches and build scripts for all binaries are available using the source links above. You can browse the tools directory here.
    ISO
    If you have the bandwidth / patience you can pull absolutely everything in a single ISO image:
    SnapGear Embedded Linux Distribution [iso]
    Otherwise, please visit our buy page for information about how you can get a CD shipped to you.
    Archives
    You can find older versions, if any, in the archive directory.
    Nhưng em chưa rõ lắm phải sử dụng snapgear này thế nào? làm nó thành một entry khi khởi động chăng! (em mới bắt đầu 1 tuần với linux)
    http://www.snapgear.org/snapgear/documentation.html
    Dưới đây là các bước:
    Documentation
    Documentation is included with the src packages, but this page will help you get up and running quickly.
    Instructions for compiling:
    1. Install a tool chain. If you are using a binary tool chain package then install that now. If you are building your own tool chain, then do that now.
    2. Un-archive the source package. It is a gziped tar image, so do:
    tar xvzf snapgear-XXXXXXXX.tar.gz
    This will dump the source into a snapgear directory. Typically you would do this somewhere in your local user directory. (Good practice dictactes that you don't build things like this as root :-)
    3. Cd into the source tree:
    cd snapgear
    4. Configure the Linux kernel. Configure the build for your specific target. Do the following:
    make xconfig
    Or you can use the menuconfig or config make target if you are not running the X windows system on your development machine.
    The top level selection is strait forward if you know the vendor of the board you want to compile for. You can choose also to modify the underlying default kernel and application configuration if you want.
    At first I suggest using the default configuration for your vendors board. It will almost certainly work as is on your board.
    5. Build the dependencies:
    make dep
    6. Build the image:
    make
    Vậy em đang dùng Fedora thì sẽ phải thêm nó vào Grub.conf
    Em down file iso trên trang snapgear này định cài boot từ cd room nhưng không được!
    Vậy nếu có cả nhân to như vậy thì sau này việc nạp ra con device sẽ như thế nào?
    Development steps of Embedded Linux
    The following are development steps of Embedded Linux. Seeing these steps, you will know how to construct development environment for embedded linux.
    (1) Installing Linux to host PC
    (2) Installing Embedded Linux GUI Toolkit, development kit to host PC
    (3) Compiling bootloader, kernel image, filesystem for target board
    (4) Porting images compiled at the preceding step to target board
    (5) Porting Embedded Linux GUI Toolkit to target board
    (6) Developing software for target board in host PC
    (7) Porting the developed software to target board
    Tôi không biết snapgear.
    Về nhúng nhân linux lên 1 target 16/32bits, cơ bản bản phải xây dựng hệ thống filesystem (root, usr, lib...) vì linux và unix coi tất cả các thiết bị dưới dạng file và thư mục (vd file /dev/ttyS0 là file mô tả COM1).
    Vì vậy bạn setup hệ thống của họ lên host (Fedora..) là sử dụng toolkit xây dựng filesystem tương ứng với kiến trúc của target. Và căn cứ theo địa chỉ boot (vd 0xFFFF FFF0 đối vớ x86) để cài chương trình boot tương tự như grub hoặc lilo trên PC. Khi reset con trỏ sẽ bắt đầu tự địa chỉ đó và chạy chương trình boot để tìm hệ thống filesystem.
    Còn realtime, bản chất là các module được cài đặt ở cấp kernel sử dụng trực tiếp các timeslice của phần cứng, do đó nó gần như là phần cứng. Nhưng nó không phải là yêu cầu bắt buộc cho nhúng, nó phụ thuộc vào thư viện toolkit và kiến trúc target.
    Do đó, tùy thư viện, hoặc mã nguồn của toolkit (BlueCat, MiniRTL...) mà nhúng một RTOS lên target.
    uCLinux là một OS nhúng nhưng không hỗ trợ các RT công nghiệp chẳng hạn
    Opentdoors- Thành viên của Rock'n'Roll club
    pulsar Tìm hiểu thêm về pulsar
    • mansion123
      bởi mansion123
      hôm nay, 16:08
      hôm nay, 07:44
