Chào các bác, em tìm được trên trang http://www.codeskin.com/index.php/home/pages/c2oooprog
một phần mềm cho phép nạp hầu hết các loại C2000 DSP của TI qua cổng serial / CAN. Mỗi một loại được làm việc tương ứng với một tần số nhất định.
Supported Targets:
The following FLASH API's and chip clock frequencies are supported:
- TMS320LF2406A: API v1.30 External Clock: 10 MHz, PLL = x4
- TMS320LF2407A: API v1.30 External Clock: 10 MHz, PLL = x4
- TMS320LF2407A: API v1.30 External Clock: 20 MHz, PLL = x4
- TMS320F28015: API v1.00 External Clock: 20 MHz
- TMS320F28016: API v1.00 External Clock: 20 MHz
- TMS320F2802: API v3.02 External Clock: 20 MHz
- TMS320D28027: API v2.00 Internal clock (60 MHz)
- TMS320D28030: API ROM Internal clock (60 MHz)
- TMS320D28033: API ROM Internal clock (60 MHz)
- TMS320D28035: API ROM Internal clock (60 MHz)
- TMS320F2806: API v3.02 External Clock: 20 MHz
- TMS320F2808: API v3.02 External Clock: 20 MHz
- TMS320F2808: API v3.02 External Clock: 22.1184 MHz (no branching support)
- TMS320F2808: API v3.02 External Clock: 30 MHz (no branching support)
- TMS320F2808: API v3.02 External Clock: 48 MHz (no branching support)
- TMS320F2808: API v3.02 External Clock: 96 MHz (no branching support)
- TMS320F2809: API v1.00 External Clock: 20 MHz (no branching support)
- TMS320F2809: API v1.00 External Clock: 30 MHz (no branching support)
- TMS320F2810: API v2.10 External Clock: 24.576 MHz (no branching support)
- TMS320F2810: API v2.10 External Clock: 25 MHz (no branching support)
- TMS320F2810: API v2.10 External Clock: 30 MHz (no branching support)
- TMS320F2811: API v2.10 External Clock: 30 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 14.7456 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 20 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 24.576 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 25 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 27 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 28.6083 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 29.439 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 30 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 32.768 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 48 MHz (no branching support)
- TMS320F2812: API v2.10 External Clock: 50 MHz (no branching support)
- TMS320F28232: API v2.10 External Clock: 20 MHz (no branching support)
- TMS320F28234: API v2.10 External Clock: 20 MHz (no branching support)
- TMS320F28235: API v2.10 External Clock: 20 MHz (no branching support)
- TMS320F28235: API v2.10 External Clock: 25 MHz
- TMS320F28235: API v2.10 External Clock: 30 MHz
- TMS320F28235: API v2.10 External Clock: 40 MHz
- TMS320F28335: API v2.10 External Clock: 20 MHz
- TMS320F28335: API v2.10 External Clock: 24 MHz
- TMS320F28335: API v2.10 External Clock: 30 MHz
Các bác chỉ cần download phần mềm về, trong thư mục cài đặt có sẵn bootloader hex cho từng chip đó.
Nhưng đầu tiên phải nhờ ai đó có cái DSP programer, nạp bootloader vào cho DSP chip, rồi chạy C2oooProg để nạp , debug phần mềm do mình viết
Mà cái này chỉ cho phép program nhá các bác
Bác nào hứng thú thì làm thử đi, dễ hơn là đi làm một cái DSP Programmer nhỉ , còn em thì hiện tại chỉ có nhu cầu đọc con TMS320LF2406A , bác nào có khả năng thì ra tay giúp đỡ giùm
Supported Targets:
