Chip RF của Maxim tích hợp sẵn ăng ten
  • Chip RF của Maxim tích hợp sẵn ăng ten
    Maxim Delivers First RF Transceiver With Antenna Diversity Switches
    Embarking as the industry's first transceiver to integrate Rx/Tx and antenna diversity switches, the MAX2830 direct-conversion, 802.11g/b RF transceiver also squeezes in a power amplifier and crystal oscillator circuitry. Saving 10 mm x 10 mm of board space, the device is a viable candidate for Wi-Fi, PDA, VoIP, and cellular handset applications. The transceiver operates from a 2.7V to 3.6V supply and the power amp from 2.7V to 4.2V. The receiver consumes 62 mA in receive mode while achieving a noise figure of 3.3 dB, enabling a receive sensitivity of –75 dBm (64QAM OFDM) without an external low-noise amp. Additionally, the transmitter and power amp deliver a linear transmit power of +17 dBm (64QAM OFDM) after the switch. A 20 mA shutdown mode is also on chip. Available in a leadless, 48-pin 7 mm x 7 mm TQFN-EP, pricing starts at $5.97 each/1,000. MAXIM INTEGRATED PRODUCTS, Sunnyvale, CA. (800) 998-8800.
    Source: http://www.eepn.com/locator/products...313/35313.html
    Bạn nào biết cách xin sample của Maxim thì xin vài con về dùng:
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/5367
    Key Features
    * 2.4GHz to 2.5GHz ISM Band Operation
    * IEEE 802.11g/b Compatible (54Mbps OFDM and 11Mbps CCK)
    * Complete RF Transceiver, PA, Rx/Tx and Antenna Diversity Switch, and Crystal Oscillator
    o Best-in-Class Transceiver Performance
    o 62mA Receiver Current
    o 3.3dB Rx Noise Figure
    o -75dBm Rx Sensitivity (54Mbps OFDM)
    o No I/Q Calibration Required
    o 0.1dB/0.35° Rx I/Q Gain/Phase Imbalance
    o 33dB RF and 62dB Baseband Gain Control Range
    o 60dB Range Analog RSSI per RF Gain Setting
    o Fast Rx I/Q DC-Offset Settling
    o Programmable Baseband Lowpass Filter
    o 20-Bit Sigma-Delta Fractional-N PLL with < 20Hz Step Size
    o Digitally Tuned Crystal Oscillator
    o +17.1dBm Transmit Power (5.6% EVM with 54Mbps OFDM)
    o 31dB Tx Gain Control Range
    o Integrated Power Detector
    o Fully Integrated RF Input and Output Matching and DC Blocking
    o Serial or Parallel Gain-Control Interface
    o > 40dB Tx Sideband Suppression Without Calibration
    o Rx/Tx I/Q Error Detection
    * Transceiver Operates from +2.7V to +3.6V
    * PA Operates from +2.7V to +4.2V
    * Low-Power Shutdown Mode
    * Small 48-Pin Thin QFN Package (7mm x 7mm x 0.8mm)
    Applications
    General 2.4GHz ISM Radios
    Wi-Fi, PDA, VoIP, and Cellular Handsets
    Wireless Speakers and Headphones
    Con MAX 2830 này em thích lắm nhưng vào Web nó Ship hay Sample không thấy nó (Maxim) trả lời.
    Tức quá em đăng ký ship về địa chỉ người nhà tại Úc cũng ... chẳng ăn thua.
    Làm sao bi giờ hả anh picvendor ?
    Lan Hương.
      Lan Hương.
      Địa chỉ ở Úc nhưng IP VN thì vô hiệu. Fake IP sang Úc rồi thử lại
        Lan Hương.
        chị Lan Hương đã có mạch nào của con này chưa? post lên cho em xem với
        em cũng đang làm mạch thiết kế về con Max2829 mà chưa biết bắt đầu từ đâu đây
          Anh vẫn IP Việt nam mà samples qua Nertherlands ầm ầm đó thôi. Em HL chỉ anh vài chiêu anh samples cho
            Nguyên văn bởi bxngoc Xem bài viết
            Anh bxngoc có thể xin cho em con Max2829 được ko?
            nhưng mà phải sample về Việt Nam chứ, em ko có người quen ở nước ngoài
              bác nào biết chân ra anten của con max2829 là gì thì làm ơn chỉ cho em cái , với lại thường thường thì những chân như kiểu đó ký hiệu là gì trong pin decription
                hj hj , đi dòng dòng tìm đũ thứ không bằng vô đây xem rùi ra ngoài mua là ok. hiệu wua? thiệt hen
                Cám on diễn đàn hen
                picvendor Tìm hiểu thêm về picvendor
