Cắt mạch khi quá áp hoặc dưới áp
  • Cắt mạch khi quá áp hoặc dưới áp
    This over/under voltage cut-out will save your costly electrical and electronic appliances from the adverse effects of very high and very low mains voltages. The circuit features auto reset and utilises easily available components. It makes use of the comparators available inside 555 timer ICs. Supply is tapped from different points of the power supply circuit for relay and control circuit operation to achieve reliability. The circuit utilises comparator 2 for control while comparator 1 output (connected to reset pin R) is kept low by shorting pins 5 and 6 of 555 IC. The positive input pin of comparator 2 is at 1/3rd of Vcc voltage . Thus as long as negative input pin 2 is less positive than 1/3 Vcc, comparator 2 output is high and the internal flip-flop is set, i.e. its Q output (pin 3) is high. At the same time pin 7 is in high impedance state and LED connected to pin 7 is therefore off. The output (at pin 3) reverses (goes low) when pin 2 is taken more positive than 1/3 Vcc. At the same time pin 7 goes low (as Q ouptput* of internal flip- flop is high) and the LED connected to pin 7 is lit. Both timers (IC1 and IC2) are configured to function in the same fashion. Preset VR1 is adjusted for under voltage (say 160 volts) cut-out by observing that LED1 just lights up when mains voltage is slightly greater than 160V AC. At this setting the output at pin 3 of IC1 is low and transistor T1 is in cut-off state. As a result RESET* pin 4 of IC2 is held high since it is connected to Vcc via 100 kilo-ohm resistor R4. Preset VR2 is adjusted for over voltage (say 270V AC) cut-out by observing that LED2 just extinguishes when the mains voltage is slightly less than 270V AC. With RESET* pin 4 of IC2 high, the output pin 3 is also high. As a result transistor T2 conducts and energises relay RL1, connecting load to power supply via its N/O contacts. This is the situation as long as mains voltage is greater than 160V AC but less than 270V AC. When mains voltage goes beyond 270V AC, it causes output pin 3 of IC2 to go low and cut-off transistor T2 and de-energise relay RL1, in spite of RESET* pin 4 still being high. When mains voltage goes below 160V AC, IC1’s pin 3 goes high and LED1 is extinguished. The high output at pin 3 results in conduction of transistor T1. As a result collector of transistor T1 as also RESET* pin 4 of IC2 are pulled low. Thus output of IC2 goes low and transistor T2 does not conduct. As a result relay RL1 is de-energised, which causes load to be disconnected from the supply. When mains voltage again goes beyond 160V AC (but less than 270V AC) the relay again energises to connect the load to power supply
    Nhìn mạch trên thì cái rơ-le chả bao giờ tác động
      Theo bài trên thì mạch sẽ cắt khi điện áp dưới 160 hay trên 270V.
      Cho tôi hỏi:
      Dòng đem so sánh ta đã ổn định mức 9V rồi thì
      - Con 555 sẽ so áp như thế nào? Theo mạch trên thì khi ta cho điện áp ngõ vào 160V (low) chiết áp VR1 ta sẽ chỉnh cho chân số 2 xuống thấp hơn mức 3V (1/3 của 9V) thì dòng ở pin 2 sẽ là ứng với mức khi dòng ngoài 160V.
        Không hiểu biết gì về 555 cũngc thấy mạch bên Lower limit chẳng tác động gì đến relay cả
        Núi cao bởi có đất bồi
        Muôn dòng sông đổ biển sâu
          Em cũng đang muốn làm một mạch với chưc năng như thế.Các bác cứ thảo luận và hi vọng em sẽ tiếp thu được và ráp thành công mạch điện này.Nơi em ở điện áp nó cứ nhảy lung tung phèng vậy.Mong các bác giúp cho nhé!
            mach bao ve phu tai
            Đây là một mạch em sưu tầm được các bác xem thữ và thấy khả quan thì cho ý kiến để em ráp nhé.cảm ơn các bác nhiều!
              ảnh gữi kèm!
                mạch quá áp
                -p1 định mức tắt.
                -chú ý: phải chọn biến thế chịu được điện áp cao( 250v-300v), vì với loại biến áp nầy nó không dễ bị hư khi nguồn AC ở mức áp cao.
                lavie Tìm hiểu thêm về lavie
