Mấy bác cho em hỏi mosfet kênh P con nào chịu khoảng 500 V, dòng >3A thì chỉ cho em với.em tìm được con Irf 840 kênh N rồi, bây giờ đang săn con kênh P để làm cái cầu H cho mạch nghịch lưu.Thanks mấy bác.
Mosfet kênh P
mình cho bạn bảng linh kiện FET tha hồ mà chọn
STT Ký hiệu Loại kênh dẫn Đặc điểm kỹ thuật
1 2SJ306 P-Channel 3A , 25W
2 2SJ307 P-Channel 6A, 30W
3 2SJ308 P-Channel 9A, 40W
4 2SK1038 N-Channel 5A, 50W
5 2SK1117 N-Channel 6A, 100W
6 2SK1118 N-Channel 6A, 45W
7 2SK1507 N-Channel 9A, 50W
8 2SK1531 N-Channel 15A, 150W
9 2SK1794 N-Channel 6A,100W
10 2SK2038 N-Channel 5A,125W
11 2SK2039 N-Channel 5A,150W
12 2SK2134 N-Channel 13A,70W
13 2SK2136 N-Channel 20A,75W
14 2SK2141 N-Channel 6A,35W
15 2SK2161 N-Channel 9A,25W
16 2SK2333 N-FET 6A,50W
17 2SK400 N-Channel 8A,100W
18 2SK525 N-Channel 10A,40W
19 2SK526 N-Channel 10A,40W
20 2SK527 N-Channel 10A,40W
21 2SK555 N-Channel 7A,60W
22 2SK556 N-Channel 12A,100W
23 2SK557 N-Channel 12A,100W
24 2SK727 N-Channel 5A,125W
25 2SK791 N-Channel 3A,100W
26 2SK792 N-Channel 3A,100W
27 2SK793 N-Channel 5A,150W
28 2SK794 N-Channel 5A,150W
29 BUZ90 N-Channel 5A,70W
30 BUZ90A N-Channel 4A,70W
31 BUZ91 N-Channel 8A,150W
32 BUZ 91A N-Channel 8A,150W
33 BUZ 92 N-Channel 3A,80W
34 BUZ 93 N-Channel 3A,80W
35 BUZ 94 N-Channel 8A,125W
36 IRF 510 N-Channel 5A,43W
37 IRF 520 N-Channel 9A,60W
38 IRF 530 N-Channel 14A,88W
39 IRF 540 N-Channel 28A,150W
40 IRF 610 N-Channel 3A,26W
41 IRF 620 N-Channel 5A,50W
42 IRF 630 N-Channel 9A,74W
43 IRF 634 N-Channel 8A,74W
44 IRF 640 N-Channel 18A,125W
45 IRF 710 N-Channel 2A,36W
46 IRF 720 N-Channel 3A,50W
47 IRF 730 N-Channel 5A,74W
48 IRF 740 N-Channel 10A,125W
49 IRF 820 N-Channel 2A,50W
50 IRF 830 N-Channel 4A,74W
51 IRF 840 N-Channel 8A,125W
52 IRF 841 N-Channel 8A,125W
53 IRF 842 N-Channel 7A,125W
54 IRF 843 N-Channel 7A,125W
55 IRF 9610 P-Channel 2A,20W
56 IRF 9620 P-Channel 3A,40W
57 IRF 9630 P-Channel 6A,74W
58 IRF 9640 P-Channel 11A,125W
59 IRFI 510G N-Channel 4A,27W
60 IRFI 520G N-Channel 7A,37W
61 IRFI 530G N-Channel 10A,42W
62 IRFI 540G N-Channel 17A,48W
63 IRFI 620G N-Channel 4A,30W
64 IRFI 630G N-Channel 6A,35W
65 IRFI 634G N-Channel 6A,35W
66 IRFI 640G N-Channel 10A,40W
67 IRFI 720G N-Channel 3A,30W
68 IRFI 730G N-Channel 4A,35W
69 IRFI 740G N-Channel 5A,40W
70 IRFI 820G N-Channel 2A,30W
71 IRFI 830G N-Channel 3A,35W
72 IRFI 840G N-Channel 4A,40W
73 IRFI 9620G P-Channel 2A,30W
74 IRFI 9630G P-Channel 4A,30W
75 IRFI 9640G P-Channel 6A,40W
76 IRFS 520 N-Channel 7A,30W
77 IRFS 530 N-Channel 9A,35W
78 IRFS 540 N-Channel 15A,40W
79 IRFS 620 N-Channel 4A,30W
80 IRFS 630 N-Channel 6A,35W
81 IRFS 634 N-Channel 5A,35W
82 IRFS 640 N-Channel 10A,40W
83 IRFS 720 N-Channel 2A,30W
84 IRFS 730 N-Channel 3A,35W
85 IRFS 740 N-Channel 3A,40W
86 IRFS 820 N-Channel 2A-30W
87 IRFS 830 N-Channel 3A-35W
88 IRFS 840 N-Channel 4A-40W
89 IRFS 9620 P-Channel 3A-30W
90 IRFS 9630 P-Channel 4A-35W
91 IRFS 9640 P-Channel 6A-40W
92 J177(2SJ177) P-Channel 0.5A-30W
93 J109(2SJ109) P-Channel 20mA,0.2W
94 J113(2SK113) P-Channel 10A-100W
95 J114(2SJ114) P-Channel 8A-100W
96 J118(2SJ118) P-Channel 8A
97 J162(2SJ162) P-Channel 7A-100W
98 J339(2SJ339) P-Channel 25A-40W
99 K30A/2SK304/ 2SK30R N-Channel 10mA,1W
100 K214/2SK214 N-Channel 0.5A,1W
101 K389/2SK389 N-Channel 20mA,1W
102 K399/2SK399 N-Channel 10-100
103 K413/2SK413 N-Channel 8A
104 K1058/2SK1058 N-Channel
105 K2221/2SK2221 N-Channel 8A-100W
106 MTP6N10 N-Channel 6A-50W
107 MTP6N55 N-Channel 6A-125W
108 MTP6N60 N-Channel 6A-125W
109 MTP7N20 N-Channel 7A-75W
110 MTP8N10 N-Channel 8A-75W
111 MTP8N12 N-Channel 8A-75W
112 MTP8N13 N-Channel 8A-75W
113 MTP8N14 N-Channel 8A-75W
114 MTP8N15 N-Channel 8A-75W
115 MTP8N18 N-Channel 8A-75W
116 MTP8N19 N-Channel 8A-75W
117 MTP8N20 N-Channel 8A-75W
118 MTP8N45 N-Channel 8A-125W
119 MTP8N46 N-Channel 8A-125W
120 MTP8N47 N-Channel 8A-125W
121 MTP8N48 N-Channel 8A-125W
122 MTP8N49 N-Channel 8A-125W
123 MTP8N50 N-Channel 8A-125W
124 MTP8N80 N-Channel 8A-75W
Help Me
chào các pác.
Em đnag sửa con UPS.Nó bị nổ tung con IRFP90N20D.
con này dòng và áp trâu quá,Vdss=200V.Id=94A
Em đang kiếm con tương tự nó để thay vào mạch
Mà ko biết con nào được.Các pác kiếm giúp em với.
Có gì pác gửi vào mail cho em với,nếu có thể cho em biết luôn cả địa chỉ mua Linh kiện con này với trantap.45@gmail.com
Em cảm ơn các pác nhiều.Last edited by trantap.45; 29-11-2010, 14:14.
Trả lời cho Tìm linh kiện sửa loa vi tính.bởi nhathung1101Ra cửa hàng điện tử bất kỳ.
Dõng dạc hét lên:
- Cho 1 con 4558.
Có luôn. Nó chỉ là con Opamp cùi bắp thông thường thôi mà. Giá 2k hay 3k gì đó.
Nếu muốn âm thanh hay hơn, thì mua NE5535, mất 2 cốc beer thôi.-
Hôm qua, 22:38 -
Trả lời cho Hỗ trợ tìm linh kiện mạch hạ áp 220V - 110Vbởi nhathung1101Mạch dùng được, nhưng phải kết hợp với Transistor NPN công suất bên ngoài. Loại chịu điện áp cao, dòng lớn.
Loại mạch này nhái theo cái loại IC họ STR trong mấy cái ti vi cổ lỗ ngày xưa thôi mà. Còn được gọi là "ổn áp...-
Hôm qua, 22:28 -
Trả lời cho Tìm linh kiện sửa loa vi tính.bởi Nikon57
Hôm qua, 21:36 -
bởi Nikon57Bộ loa vi tính Microlap cũ của tôi tầng tiền khuyêchs đại bị lỗi. Sau kiểm tra , nguyên nhân là do con chíp 4558D JRC 0077C chết nóng rực. Không thêt tìm được con IC đúng nguyên mã như vậy, để thay thế tôi có thể thay bawngfcon IC 4558 JRC 0058T được không? Mong các bác thành thạo cho ý kiến.
Hôm qua, 21:36 -
Trả lời cho Hỗ trợ tìm linh kiện mạch hạ áp 220V - 110Vbởi dinhthuong80Mạch trên nếu dùng vào việc khác ( theo người thiết kế ra nó) thì cũng được: làm mạch tiền khuếch đại (pre-Amply) cho "con sò công suất" hay mạch công suất, để chạy cái loa cũng tạm ok.
Các chữ E,B,C trên mạch trên gắn...-
Hôm qua, 16:47 -
Trả lời cho Hỗ trợ tìm linh kiện mạch hạ áp 220V - 110Vbởi iTronvây là mình đã hiểu lí do vì sao ông ấy lại đưa mình nguyên hộp có hơn chục cái mạch này trong đó...
Hôm qua, 12:21 -
Trả lời cho Hỗ trợ tìm linh kiện mạch hạ áp 220V - 110Vbởi mèomướpDạ mạch này hông dùng được ạ. Chú sang chị hàng xóm mượn cái cuốc kiếm góc nào trong bản có nhìu người qua lại để trồng 1 cây cải ngồng, ngày ngày chú chịu khó qua đấy tưới chăm cho nó lớn ạ, vài tháng sau nó to chú mang ra chợ bán...
Hôm qua, 12:13 -
bởi iTronEm được ông anh cho mạch như hình, nhờ ace trong diễn đàn xem giúp mạch này dùng ổn ko và dùng linh kiện công suất nào thì phù hợp.
Xin cảm ơn...-
Hôm qua, 11:27 -
Trả lời cho Tiếng Anh cho người Việtbởi dinhthuong80Vì sản phẩm của họ dân mình có dùng, và có lẽ cũng không phải là không phổ biến, nên ĐT quyết định gởi thư điện tử tiếng Anh cho họ như sau, ( đã sửa vài từ như được góp ý, vì nếu lịch sự thì dù vòng vo cũng nên phản hồi, vì...
25-02-2025, 16:36 -
Trả lời cho Tiếng Anh cho người Việtbởi tuyennhanCái thư sai ngay câu chào Dear sir mới đúng Hi chỉ dùng cho người quen , các vấn đề về kỹ thuật nó không trả lời hoặc nói loanh quanh tránh ảnh hưởng đến công ty .
Giup1 người cần không giúp người không cần với lại văn mình vợ người nha đừng quên .-
23-02-2025, 07:44 -
