AE dien dan huong dan dum IC:HOLTEK---HT48R05A-1 ---18 chan, cua dau dia CALIFORNIA 138KB nam o phia duoi bo hinh la ic gi vay,no lam nhiem vu gi,neu bi hu thi xuat hien benh gi?pan nhu the nao?Xin huong dan gium.XIN CAM ON.
Huong dan dum ic
Nguyên văn bởi libi Xem bài viếtAE dien dan huong dan dum IC:HOLTEK---HT48R05A-1 ---18 chan, cua dau dia CALIFORNIA 138KB nam o phia duoi bo hinh la ic gi vay,no lam nhiem vu gi,neu bi hu thi xuat hien benh gi?pan nhu the nao?Xin huong dan gium.XIN CAM ON.
tell : 0914058545
hôm nay, 06:08 -
hôm nay, 01:38 -
hôm nay, 01:26 -
14-02-2025, 00:42 -
13-02-2025, 17:02 -
13-02-2025, 08:43 -
13-02-2025, 07:39 -
13-02-2025, 07:22 -
