Lỗi Main P4MDUT Bật lên nguồn rồi ngừng ngay!
  • Lỗi Main P4MDUT Bật lên nguồn rồi ngừng ngay!
    Main: Jetway P4MDUT VIA P4M266A Socket 478 mATX MB w/VID & SND
    Ai biết lỗi này chỉ giúp em với!
    Mô tả:
    1. Cắm đầy đủ dây nguồn 20 chân và nguồn 4 chân thì: bật quạt quay rồi dừng ngay!
    2. Chỉ cắm dây nguồn 20 chân bật rồi bật nguồn thì chạy nhưng ko lên gì cả!
    Đã thay thử nguồn, chip, ram khác nhưng vẫn ko được!
    Em đoán nó bị chập cái gì đó!
    Ai biết vè main giúp em cái này với !!
    Thanks!
    Info:
    Product Features Pacific Geek computer parts
    Upgrade your system today with this excellent motherboard from Jetway! The Jetway P4MDUT is a Socket 478 motherboard powered by the VIA P4M266A + VT8235 chipset and features support for Intel Pentium 4 and Celeron processors with up to 533 MHz bus speeds!
    The P4MDUT features two 184-pin DIMM slots for adding up to 2 GB of DDR memory! Add a powerful graphics card to the AGP slot and add other peripherals to the three PCI slots! Integrated 10/100 Fast Ethernet is included along with integrated 6-channel audio! Save big and order now!
    Features/Specifications:
    Jetway P4MDUT VIA P4M266A Socket 478 mATX Motherboard
    General Features:
    Socket 478
    mATX form factor
    Supports up to 2 GB DDR SDRAM
    Integrated audio chipset
    Integrated video chipset
    VIA VT6103 integrated LAN
    Two (2) IDE channels
    One (1) floppy connector
    20-pin ATX power connector
    Expansion slots:
    Two (2) 184-pin DDR DIMM sockets
    Three (3) PCI slots
    One (1) AGP slot
    I/O ports:
    Two (2) PS/2 ports
    One (1) 9-pin Serial port1
    One (1) VGA connector
    One (1) Parallel port
    Six (6) USB 2.0 ports (two on back, four via internal header)
    Mic in, Line in, Line out jacks
    One (1) Game/MIDI port
    Supported Processors:
    Supports Intel Pentium 4 processor and Celeron processors
    Socket 478 (mPGA478)
    533/400 MHz bus speed
    Regulatory Approvals:
    CE
    Package Includes:
    User Guide
    Driver CD
    Additional Information:
    Notes:
    Model: P4MDUT
    Note: PCB color may vary
    Product Requirements:
    ATX case
    ATX power supply
    Supported processor and memory
    AGP video card
    Rest of system
    Em tìm thấy cái này: ko biết có phải nó ko ? em ko biết cách đo (có cái đồng hồ số A830L)
    Nguyên văn bởi Driverless Xem bài viết
    chập đường 12v. tháo đường 12V 4 pin ra thì quạt quay nhưng máy không động đậy. Đo kiểm thì thấy đi mấy em FET cấp nguồn CPU.
      Main của bạn bị chập FET nguồn cấp cho CPU, tháo chip ra rồi đo nếu D và S thông nhau là FET chết chập. Thường để nguyên trong main thì khó đo và không chính xác bằng tháo FET ra ngoài. Để xác định xem cặp FET nào bị chết (dò) thì bạn mắc nối tiếp một bóng đèn 12V-35W vào đường 12V (giắc 4 chân) rồi cho main chạy ít phút, nếu FET nào nóng hỏng.
      viptrongpro Tìm hiểu thêm về viptrongpro
        hôm nay, 07:44
