Anh em ai có fw tivi VTB MODEL F2541 Khiển S3P8849XZZ ,NHÓ 24C04 .Giải ma NN5198K cho mình xin.Cám ỏn anh em nhiều.
Xin fw vtb
I. PHÖÔNG PHAÙP CAÂN CHÆNH :
1/ Nhaán vaø giöõ cuøng luùc 2 phím “PROG+/PROG-“ roài môû coâng taéc nguoàn chính ñeå vaøo Baûng maõ heä thoáng.
2/ Nhaán vaø giöõ 2 phím “P.M & S.M” ñoàng thôøi cho ñeán khi coù söï thay ñoåi maøu treân maøn hình ñeå vaøo cheá ñoä RESET.
3/ Taét maùy vaø khôûi ñoäng laïi.
* * Caùc böôùc treân chæ söû duïng khi thay ROM, döõ lieäu ROM ñöôïc naïp tröôùc taïi Coâng ty.
4/ Ñeå vaøo muïc caân chænh, nhaán vaø giöõ cuøng luùc 2 phím “VOL+/VOL-“ roài môû coâng taéc nguoàn chính.
5/ Ñeå laät trang 1 ñeán 4, nhaán phím MENU.
Ñeå choïn muïc, nhaán phím PROG+/-.
Ñeå caân chænh, nhaán phím VOL+/-.
6/ Ñeå thoaùt ra ngoaøi, taét coâng taéc nguoàn chính.
II. DÖÕ LIEÄU :
TRANG 1 :
ITEM FUNCTION RANGE DATA REMARK
RF-AGC Align RF AGC Threshold 00 – 7F 2D
VIFDET NEG Align IF Video Level 00 – 7F
VIFDET INT Align IF Video Level 00 – 7F 00
VIFDET EXT Align IF Video Level 00 – 7F 00
RGB-LIMIT 00 - 07 04
TRANG 2 :
CUTOFF-R Align Red Out DC Level 00 - FF 3F ADJ
CUTOFF-G Align Green Out DC Level 00 - FF 3F ADJ
CUTOFF-B Align Blue Out DC Level 00 - FF 3F ADJ
DRIVE-R Align Red Out AC Level 00 – 7F 3F ADJ
DRIVE-B Align Blue Out AC Level 00 – 7F 3F ADJ
SUB-BRIGHT Align Common RGB DC Level 00 – 7F 4F ADJ
TRANG 3 :
V-POSITION Vertical Position 00 - 07 02 (00) ADJ
H-POSITION Horizontal Position 00 – 1F 0B (0C) ADJ
V-EHT Vertical Shape 00 – 0F 00 ADJ
H-EHT Horizontal Shape 00 – 0F 00 ADJ
TRANG 4 :
V-AMP Vertical Size 00 – 7F 11 (18) ADJ
V-LINE Vertical Linearity 00 – 3F 10 (11) ADJ
V-SC3 Vertical S-Correction X 00 – 3F 06 (0F) ADJ
H-AMP Horizontal Size 00 – 3F 27 (28) ADJ
EW-PARA Pincustion 00 – 3F 1E (24) ADJ
EW-COR Pincustion Corner 00 – 0F 02 (0A) ADJ
TRAPER Trapezium 00 – 3F 17 (15) ADJ
V-SC5 Vertical S-Correction X 00 – 0F 08 (08) ADJ
* Caùc döõ lieäu trong ngoaëc (…) cho heä 60Hz.
III. BAÛNG MAÕ HEÄ THOÁNG :
STT 1 2 3 4 5 6 7 8 9 A
DATA 1 1 7 7 4 0 4 6 * *
* Döõ lieäu maëc ñònh cuûa IC NN5199 (sau khi RESET khoâng thay ñoåi 2 giaù trò naøy).
Nguyên văn bởi DIENTUKHOA Xem bài viếtAnh em ai có fw tivi VTB MODEL F2541 Khiển S3P8849XZZ ,NHÓ 24C04 .Giải ma NN5198K cho mình xin.Cám ỏn anh em nhiều.
Nguyên văn bởi votricuong Xem bài viếtbạn dùng thử fw này xemĐIỆN TỬ-ĐĂNG KHOA-ĐT 0984.536.618
https://vn.shp.ee/dWYVgq7-
Hôm qua, 12:48 -
Hôm qua, 11:55 -
Hôm qua, 00:47 -
Hôm qua, 00:16 -
19-01-2025, 19:00 -
19-01-2025, 15:47 -
18-01-2025, 20:47 -
18-01-2025, 20:42 -
18-01-2025, 18:56 -
17-01-2025, 21:36 -
