CÁC BÁC GIÚP EM VỚI EM CÓ CON SAMSUNG CS - 21K30MG ic TDA9594PS/N3/4/1639 NÓ DANG CHẠY THÌ CO DOC CÒN 10CM THÍ EM THÁO LÁI DÒNG RA THẤY CHẬP EM SỬ LÝ XONG VÀ CHO YEN TÂN LÊN THAY LUÔN CẢ TỤ NHỤ NỮA , MÀ GIỜ MỞ MÁY CHẠY THÌ CAO ÁP DÉO 1 CÁI TẮT CHỜ LUÔN KO BIẾT SAO NỮA ( THAY CAO ÁP MỚI VẪN VẬY). MONG CÁC BÁC GIÚP ĐỠ
Cs - 21k30mg
Hôm qua, 23:21 -
Hôm qua, 23:11 -
Hôm qua, 23:01 -
Hôm qua, 08:09 -
Hôm qua, 06:19 -
24-01-2025, 19:40 -
24-01-2025, 19:31 -
24-01-2025, 12:08 -
24-01-2025, 12:05 -
24-01-2025, 11:39 -
