cái đó có tên là dao động j nhỉ? cái tran như thế lại có dòng chảy từ E->C ah? lần đầu tiên mình biết mạch này. 1 tran ko cần cuộn hồi tiếp. rất hay các bạn ah.
"điều quan trọng khi lập nghiệp ko phải ở thành phố hay ở quê, mà quan trọng là chúng ta nhận định ra hướng đi nào là đúng"
yahoo:
gmail:
e tìm thấy tài liệu về mạch này rồi. bác nào giỏi tiếng anh dịch cho a e trên diễn đàn rõ với
nguyên văn của nó đây:
"UNCONVENTIONAL CIRCUITS:
The following circuit converts 1.5v to a voltage that is higher than the reverse break-down voltage of the emitter-collector junction of the BC547. When this voltage is reached the junction breaks-down and creates a low voltage across it. This allows the voltage on the 100u to pass to the white LED and create a flash. The voltage across the 100u drops and the junction comes out of conduction and the cycle repeats.
The next circuit uses the same "Junction Breakdown" phenomenon but this time the high voltage is supplied by a 12v to 20v battery.
All transistors have a single junction or two junctions between each pair of leads. They are called a "PN" junction or a PNP junction or an NPN junction - depending on which leads are selected. The junctions between each pair of leads behave differently, however the junction(s) we are interested in, is between the collector and emitter leads.
When a voltage is applied to these leads in the reverse direction, an unusual thing happens.
As the voltage is increased, the junction suddenly breaks down and a high current will flow , according to the energy available from the electrolytic. This occurs at a voltage of between 12v and 20v, (some transistors will require a higher voltage) depending on the type of transistor and the manufacturer. When the voltage across the leads falls, the current stops.
In other words, the resistance between the two leads decreases when the voltage rises to between 12v and 20v (and the voltage across the two leads is about 0.5v and this is a characteristic of the junction). When the supply-voltage drops, the junction-resistance increases and the electrolytic charges.
This feature can be used to flash a LED as shown in the following diagram:
Flasher circuit using "Junction Breakdown"
The circuit above is very unreliable and only works with some transistors. The voltage is very important. It must be high enough to cause the junction(s) between the emitter and collector leads to breakdown.
The flash-rate will depend on the value of the top resistor and the electrolytic and also the voltage at which the transistor break-down. The circuit consumes less than 1mA and the 100R prevents a high current flowing through the LED (from the electrolytic). Without the 100R, the LED is destroyed instantly.
The circuit is a very good demonstration of breakdown but due to the high supply voltage needed, it is not a practical design. The previous circuit should be used."
trưa trưa đi học về dịch tầm bậy tầm bạ cho, mạch này mình nghĩ nó hoạt động theo kiểu đặc tính tự khuyếch đại dòng rò cuả trans, còn việc dẫn từ E--->C là bình thường
Sai lầm từ cơ bản.
Nguyên tắc cánh quạt là "múc" không khí trước cánh quạt quăng lên "Bờ". Khi cánh quạt di chuyển để lại vị trí có áp suất thấp, không khí ở ngoài tràn vào. Cánh quạt thứ 2 làm việc giống thế, rồi đến cánh quạt...
"nếu tăng nó lên đến 90 độ thì không thổi nữa, tăng tiếp trên 90 độ nó sẽ trở thành quạt hút thôi."
là sau khi tăng lên thành 90° rồi, tiếp tục tăng nữa cho nó trên 90° đó bác, như hình vẽ xấu tệ ở dưới ạ!
1. Có lẽ cháu nói "ma sát" ở đây chưa được rõ ràng.
Ma sát ở đây chỉ là ma sát trượt qua mặt cánh quạt, và lực ma sát do không khí này có phương vuông góc với trục quay.
Bác Vị học ở Cao thắng à thật là ngưỡng mộ , lớp đệ tứ em học ở Nguyễn thượng Hiền chỉ được học cơ khí nguội ở trường Nhân Văn trong 3 tháng hè do các thầy ở Cao Thắng dạy ....
