đồng hồ số hiển thị led 7 thanh
    Nguyên văn bởi kentsui8x Xem bài viết
    Cảm ơn pác nhiều.
    B có code asm của mạch đồng hồ 8951+ds1307 post luôn cho e tham khảo được không.
    Code của mạch bên trên ý.
    Thanks !
    Code cho mach ds1307:
    ;TIME CLOCK  FOR AT89C51 AND 1307
    ;PROGRAMER :PCT
    ;PCTCOMPUTER - 0918227077
    $MOD51
      	XUNG_NHAY	 	DATA	38H		; XUNG 100ms
     	BIEN_NHAY    	DATA	39H		;0 = SANG TAT CA DEN , 1 = NHAY led TUONG UNG KHI set
      	GIAY         	DATA	40H
      	PHUT         	DATA	41H
      	GIO          	DATA	42H
      	DONVI_GIAY   	DATA	47H
      	CHUC_GIAY    	DATA	48H
      	DONVI_PHUT   	DATA	49H
      	CHUC_PHUT    	DATA	4AH
      	DONVI_GIO    	DATA	4BH
     	CHUC_GIO     	DATA	4CH
    	PHAN_TRAM_GIAY	DATA	4DH
    	FLAG_SET		DATA	4EH 	;0 = KHONG SET , 1 = SET PHUT , 2 = SET GIO
    	LED_GIAY       	BIT		P2.0
    	LED_C_GIAY     	BIT		P2.1
     	LED_PHUT       	BIT		P2.2
    	LED_C_PHUT     	BIT		P2.3
    	LED_GIO       	BIT		P2.4
    	LED_C_GIO     	BIT		P2.5
    ;--------I2C-------
    	SCL				BIT		P3.0
    	SDA				BIT		P3.1
    	SW_1			BIT		P3.2
    	SW_2			BIT		P3.3
    	SW_3			BIT		P3.4
    	LED_DATA		EQU		P0
    	BYTE_W			EQU	11010000B
    	BYTE_R			EQU	11010001B
    	ADD_LOW			EQU	62H
    	DATA_DS			EQU	63H
    	ORG 00H
    	LJMP 	MAIN
    	ORG 0BH
    	LJMP 	NGAT_TIME
    	ORG 030H
    MAIN: 					;reset tat ca cac bien
    	MOV 	GIAY,#0
    	MOV 	PHUT,#0
    	MOV 	GIO,#0
    	MOV 	BIEN_NHAY,#0
    	MOV		XUNG_NHAY,#0
    	MOV		FLAG_SET,#0
    	MOV 	R0,#0
    	MOV 	IE,#10001010B
    	MOV 	TMOD,#11H
    	MOV 	TL0,#LOW(-9216)
    	MOV 	TH0,#HIGH(-9216)
    	SETB 	TR0
    	MOV		A,#0FFH
    	MOV		LED_DATA,A
    	MOV 	DPTR,#BANGSO
    		CLR	SCL
    		CLR	SDA
    		NOP
    		SETB	SCL
    		SETB	SDA
    		NOP
    		MOV     ADD_LOW,#00H
    		MOV     DATA_DS,#00H
    		LCALL   WRITE_BYTE
    LOOP_HIEN_THI:			; chuong trinh chinh chay tai day
    	MOV 	A,FLAG_SET
    	CJNE 	A,#0,L_HT
    	CALL 	INIT_PORT
    L_HT:
    	LCALL   HIEN_THI
    	LCALL 	SCAN_KEY
    	SJMP 	LOOP_HIEN_THI
    	INIT_PORT:
    ;==================================================READS SECONDS
    READ_SEC:
    			MOV     ADD_LOW,#00h
    			LCALL   READ_BYTE
    			MOV 	GIAY,DATA_DS
    			LCALL	I2C_STOP
    ;==================================================READS MINUTES
    			MOV     ADD_LOW,#01h
    			LCALL   READ_BYTE
    			MOV 	PHUT,DATA_DS
    			LCALL	I2C_STOP
    ;==================================================READS HOURS
    			MOV     ADD_LOW,#02h
    			LCALL   READ_BYTE
    			MOV 	GIO,DATA_DS
    			LCALL	I2C_STOP
    	RET
    ;=====stop I2C communication
    I2C_Stop:
    	CLR       SDA
    	SETB      SCL
    	NOP
    	SETB      SDA
    	RET
    ;*            WRITE DATA_DS TO DS1307 1 BYTE	*
    ;*	INPUT 	: ADD_LOW		*
    ;*		: DATA_DS			*
    WRITE_BYTE:            CLR     SDA                   ;start bit
                           CLR     SCL
                           MOV     A,#BYTE_W        ;send control byte
                           LCALL   LOOP_BYTE
                           SETB    SDA
                           SETB    SCL
                           JB      SDA,WRITE_BYTE        ;loop until busy
                           CLR     SCL
                           MOV     A,ADD_LOW             ;send address low
                           LCALL   LOOP_BYTE
                           SETB    SDA
                           SETB    SCL
                           CLR     SCL
                           MOV     A,DATA_DS                ;send DATA
                           LCALL   LOOP_BYTE
                           SETB    SDA
                           SETB    SCL
                           CLR     SDA
                           CLR     SCL
                           SETB    SCL                   ;stop bit
                           SETB    SDA
                           RET
    ;*            READ DATA FROM DS1307 1 BYTE	*
    ;* INPUT  : ADD_HIGH			*
    ;*        : ADD_LOW				*
    ;* OUTPUT : DATA_DS			*
    READ_BYTE:             CLR     SDA                   ;start bit
                           CLR     SCL
                           LCALL   LOOP_BYTE
                           SETB    SDA
                           SETB    SCL
                           JB      SDA,READ_BYTE         ;loop until busy
                           CLR     SCL
                           LCALL   LOOP_BYTE
                           SETB    SDA
                           SETB    SCL
                           CLR     SCL
                           SETB    SCL
                           SETB    SDA
                           CLR     SDA                   ;start bit
                           CLR     SCL
                           MOV     A,#BYTE_R        ;send control byte
                           LCALL   LOOP_BYTE
                           SETB    SDA
                           SETB    SCL
                           CLR     SCL
                           LCALL   LOOP_READ
                           SETB    SDA
                           SETB    SCL
                           CLR     SCL
                           SETB    SCL                   ;stop bit
                           SETB    SDA
                           RET
    ;*                      WRITE                       *
    ;* INPUT: ACC                                       *
    LOOP_BYTE:             PUSH    02H
                           MOV     R2,#08H
    LOOP_SEND:             RLC     A
                           MOV     SDA,C
                           SETB    SCL
                           CLR     SCL
                           DJNZ    R2,LOOP_SEND
                           POP     02H
                           RET
    ;*                       READ                        *
    ;* OUTPUT: ACC                                       *
    LOOP_READ:             PUSH   02H
                           MOV    R2,#08H
    LOOP_READ1:            SETB   SCL
                           MOV    C,SDA
                           CLR    SCL
                           RLC    A
                           DJNZ   R2,LOOP_READ1
                           MOV    DATA_DS,A
                           POP    02H
                           RET
    TACHSO:								; tach rieng hang chuc va hang don vi bang cach chia cho 10
    	MOV 	A,GIAY					;Lan luot chia cac Bien: Giay, Phut, Gio cho 10
    	MOV 	B,#10H 					;de tach phan Don Vi va Hang Chuc ra, de cat rieng vao cac Bien tuong ung.
    	DIV 	AB                 		;PHAN NGUYEN trong A, PHAN DU trong B
    	MOV 	CHUC_GIAY,A   			;Luu lai HANG CHUC Giay
    	MOV 	DONVI_GIAY,B  			;luu lai DON VI Giay
    	MOV 	A,PHUT
    	MOV 	B,#10H
    	DIV 	AB
    	MOV 	CHUC_PHUT,A
    	MOV 	DONVI_PHUT,B
    	MOV 	A,GIO
    	MOV 	B,#10H
    	DIV 	AB
    	MOV 	CHUC_GIO,A
    	MOV 	DONVI_GIO,B
    RET
    HIEN_THI: 							; HIEN THI LED 7 DOAN
        MOV 	A,FLAG_SET
    	CJNE 	A,#0,CHOP_NHAY
        LCALL   HIENTHI
        AJMP	THOAT_HIENTHI
    CHOP_NHAY:							; KIEM TRA BIEN NHAY VA FLAG_SET DE TAO HIEU UNG NHAY LED DANG SETING
    	MOV 	A,BIEN_NHAY
    	CJNE 	A,#0,CHOP_NHAY1
    	LCALL 	HIENTHI
    	AJMP	THOAT_HIENTHI
    CHOP_NHAY1:
    	LCALL	NHAY
    	JMP CHOP_NHAY
    THOAT_HIENTHI:
    RET
    HIENTHI:
    	LCALL 	HIENTHI_S
    	LCALL 	HIENTHI_P
    	LCALL 	HIENTHI_G
    RET
    NHAY:
    	MOV		A,FLAG_SET
    	CJNE 	A,#1,KT1
    	LCALL 	HIENTHI_S
    	LCALL 	HIENTHI_G
    KT1:
    	MOV		A,FLAG_SET
    	CJNE 	A,#2,THOAT_N
    	LCALL 	HIENTHI_S
    	LCALL 	HIENTHI_P
    THOAT_N:
    RET
    HIENTHI_S:
    			;hien thi hang don vi cua Giay
    	MOV 	A,DONVI_GIAY
    	MOVC 	A,@A+DPTR
        MOV     LED_DATA,A
        CLR 	LED_GIAY
    	LCALL 	DL
    	SETB 	LED_GIAY
        MOV 	A,CHUC_GIAY		;hien thi hang chuc cua Giay
    	MOVC 	A,@A+DPTR
        MOV 	LED_DATA,A
    	CLR 	LED_C_GIAY
    	LCALL 	DL
    	SETB 	LED_C_GIAY
    RET
    HIENTHI_P:
    	MOV 	A,DONVI_PHUT	;hien thi hang don vi cua Phut
    	MOVC 	A,@A+DPTR
    	MOV 	LED_DATA,A
    	CLR 	LED_PHUT
    	LCALL 	DL
    	SETB 	LED_PHUT
    	MOV 	A,CHUC_PHUT		;hien thi hang chuc cua Phut
    	MOVC 	A,@A+DPTR
    	MOV 	LED_DATA,A
    	CLR 	LED_C_PHUT
    	LCALL 	DL
    	SETB 	LED_C_PHUT
    RET
    HIENTHI_G:
    	MOV 	A,DONVI_GIO		;hien thi hang don vi cua gio
    	MOVC 	A,@A+DPTR
    	MOV 	LED_DATA,A
    	CLR 	LED_GIO
    	LCALL 	DL
    	SETB 	LED_GIO
    	MOV 	A,CHUC_GIO		;hien thi hang chuc cua Gio
    	MOVC 	A,@A+DPTR
    	MOV 	LED_DATA,A
    	CLR 	LED_C_GIO
    	LCALL 	DL
    	SETB	LED_C_GIO
    RET
    NGAT_TIME:
    	INC		XUNG_NHAY
    	INC 	PHAN_TRAM_GIAY   		;DAT TIMER CHAY 1/100 GIAY
    	MOV 	TL0,#LOW(-9216)
    	SETB 	TR0
    	PUSH ACC
    	PUSH PSW						;Thanh ghi trang thái chuong trình
    	MOV 	A,XUNG_NHAY				;TAO XUNG NHAP NHAY = 1/4 GIAY
    	CJNE 	A,#25,TIME1
    	MOV 	XUNG_NHAY,#0
    	INC		BIEN_NHAY
    	MOV 	A,BIEN_NHAY
    	CJNE 	A,#3,TIME1
    	MOV 	BIEN_NHAY,#0
    TIME1:
    	MOV 	A,PHAN_TRAM_GIAY		;Kiem tra bien PHAN_TRAM_GIAY - Thoat khoi ngat Time0 neu khong =
    	CJNE 	A,#100,THOAT_NGAT_TIME
    	MOV 	PHAN_TRAM_GIAY,#0		;Neu = 100 thì set bien nay = 0
    THOAT_NGAT_TIME:
    	LCALL 	TACHSO
    	POP 	PSW
    	POP 	ACC
    RETI
    SCAN_KEY:					;KIEM TRA PHIM NHAN
    SW1:				        ;SET TIME
    	JB		SW_1,SW2
    	INC		FLAG_SET
    	MOV		A,FLAG_SET
    	CJNE 	A,#3,L_SW1
    		MOV     ADD_LOW,#01H
    		MOV     DATA_DS,PHUT
    		LCALL   WRITE_BYTE
    	MOV             FLAG_SET,#0
    L_SW1:
    	LCALL	DL1
    	LCALL	DL1
    	LCALL	DL1
    	LCALL	DL1
    	LJMP	NOKEY
    SW2:						  ;SET_MIN
    	JB		SW_2,SW3
    	MOV		A,FLAG_SET
    	CJNE 	A,#0,SW20
    	LJMP	NOKEY
    SW20:
    	MOV		A,FLAG_SET
    	CJNE 	A,#1,TANG_GIO			;
    	JB		SW_2,SW3
    TANG_PHUT:
    	INC 	PHUT					;Roi tang Bien phut them 1
    	MOV 	A,PHUT
    	CJNE 	A,#60,L_SW2				;
    	MOV 	PHUT,#0					;Neu = 60 thì set bien nay = 0
    L_SW2:
    	LCALL	DL1
        LCALL	DL1
    	LJMP	SW2
    TANG_GIO:                            ;SET HOUR
    	JB		SW_2,SW3
    	MOV		A,FLAG_SET
    	CJNE 	A,#2,SW3
    	JB		SW_2,SW3
    	INC 	GIO						;Roi tang Bien Gio them 1
    	MOV 	A,GIO
    	CJNE 	A,#24,L_TANG_GIO		;Bien gio = 60? - Thoat khoi ngat Time0 neu khong =
    	MOV 	GIO,#0
    L_TANG_GIO:
    	LCALL	DL1
        LCALL	DL1
    	LJMP	TANG_GIO
    SW3:								;DANG NHAN SW3?
    	JB		SW_3,NOKEY				;KHONG NHAN SW2? KIEM TRA SW3
    	MOV		A,FLAG_SET
    	CJNE 	A,#0,SW30
    	LJMP	NOKEY
    SW30:
    	MOV		A,FLAG_SET				;DANG NHAN SW2. KIEM TRA CHE DO CHINH GIO HAY CHINH PHUT.
    	CJNE 	A,#1,GIAM_GIO			;
    	JB		SW_3,NOKEY
    GIAM_PHUT:
    	DEC 	PHUT					;Roi tang Bien phut them 1
    	MOV 	A,PHUT
    	CJNE 	A,#-1,L_SW3			;Bien Phut = -1? - Thoat khoi ngat Time0 neu khong =
    	MOV 	PHUT,#59			;Neu = -1 thì set bien nay = 60
    L_SW3:
    	LCALL	DL1
        LCALL	DL1
    	LJMP	SW3
    GIAM_GIO:
    	JB		SW_3,NOKEY
    	MOV		A,FLAG_SET
    	CJNE 	A,#2,NOKEY
    	LCALL	HIENTHI
    	JB		SW_3,NOKEY
    	DEC 	GIO						;Roi Giam Bien Gio them 1
    	MOV 	A,GIO
    	CJNE 	A,#-1,L_GIAM_GIO				;Bien gio = -1? - Thoat khoi ngat Time0 neu khong =
    	MOV 	GIO,#23
    L_GIAM_GIO:
    	LCALL	DL1
        LCALL	DL1
    	LJMP 	GIAM_GIO
    NOKEY:
    RET
    DL:
    	MOV 	R7,#200
    	DJNZ 	R7,$
    	RET
    DL1:
     PUSH 00H
     PUSH 01H
     MOV R1,#20O
    DEL:
    LCALL   HIEN_THI
    LCALL   HIEN_THI
    LCALL   HIEN_THI
     MOV R0,#250
     DJNZ R0,$
     DJNZ R1,DEL
     POP 01H
     POP 00H
    RET
    DELAY_1MS:
    	MOV 	R7,#200
    DL_1MS_1:
    	MOV 	R6,#200
    	DJNZ 	R6,$
    	DJNZ 	R7,DL_1MS_1
    RET
    DELAY:
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    	NOP
    RET
    BANGSO:
    	DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H
    RET
    END
    PCT COMPUTER
    (Để không làm ảnh hưởng đến thời gian và công việc cá nhân. Xin vui lòng không nhắn tin và điện thoại)
      Cảm ơn bác ptcom nhé.
        Có ai đã gặp trường hợp mạch đã có pin 3V nuôi cho DS1307 mà vẫn không lưu được giờ ko.Có nghĩa là khi mất điện nó tự chạy về giờ mà mình thiết lập ban đầu
          Nguyên văn bởi fet01 Xem bài viết
          - Bạn nên kiểm tra lại pin.
          - Thay ds1307
          Nếu vẫn bị như cũ thì bạn phải kiểm tra code xem sao, coi chừng nó là "hồn Trương Ba mà da anh hàng thịt "rùi. Í tui nói là Ds1307 gắn và cho có thôi, nhưng code không sử dụng nó. Cái này thường mấy bạn SV đi đặt người khác làm "đề tài" hay bị lắm ....
          PCT COMPUTER
            [QUOTE=pctcom;280758]Mạch đồng hồ dùng 8951 và IC thời gian thực DS1307 dùng pin 3v rời:
            bạn giúp cho mình xin code mạch đồng hồ này với. rất mong được sự giúp đỡ của bạn
            vansynghi@gmail.com
              [quote=pctcom;280758]Mạch đồng hồ dùng 8951 và IC thời gian thực DS1307 dùng pin 3v rời:
              bạn giúp cho mình xin code (ngôn ngữ C ) mạch đồng hồ này với. rất mong được sự giúp đỡ của bạn
              vansynghi@gmail.com
                Chào pác pctcom!
                pác xem lại hộ em cái đồng hồ dùng ds1307 với.
                Em mô phỏng trên proteus, no chạy rồi nhưng chỉnh thòi gian thì không được.
                Pác giúp e nhé.
                Thanks!
                  Chào pác pctcom!
                  Pác giúp e nhé.
                  Thanks!
                  Code này đã test tốt trên mạch thật. Mô phỏng trên Proteus cũng chưa chắc là chính xác đâu bạn. Bạn gởi file Proteus để tôi test thử xem.
                  PCT COMPUTER
                    Nguyên văn bởi pctcom Xem bài viết
                    bác có mạch đồng hồ hiển thị ngày giờ ko bác ? nếu có bác cho me với . mạch và code nha bác
                      cần giúp
                      có bác nào có chương trình và mạch của đồng hồ 4 led 7 thanh dùng 89s52chỉ cần hiển thị giờ và phút thui không.
                      gửi giúp em vào mail (quanghuan1289@gmail.com) được không ạ.
                      em cảm ơn các bác nhiều!
                        Pác pctcom test hộ e với nhé.Em dùng proteus 7.6.
                        Nó có mấy file nên e upload lên mediafire.
                        http://www.mediafire.com/?4u7e438l7v2tf94
                          Đã sửa file Proteus cho bạn rồi đây:
                          http://public.blu.livefilestore.com/...ownload&psid=1
                          PCT COMPUTER
                          • #28
                            Pác pctcom ơi.
                            Link bị gãy rồi.Em không down được.
                            Pác up lại hộ e với.
                            • #29
                              Đường Link mới đây:
                              PCT COMPUTER
                              • #30
                                Code ASM cua mạch 12c887:
                                ; ASM51
                                ;PROGRAMER :PCT
                                ;PCTCOMPUTER 0918227077 pct@pctco.net
                                $MOD51
                                XUNG_NHAY DATA 38H
                                BIEN_NHAY DATA 39H ;0 = SANG TAT CA DEN , 1 = NHAY CHOP DEN TUONG UNG KHI CHON TU SW1
                                GIAY DATA 40H
                                PHUT DATA 41H
                                GIO DATA 42H
                                DONVI_GIAY DATA 43H
                                CHUC_GIAY DATA 44H
                                DONVI_PHUT DATA 45H
                                CHUC_PHUT DATA 46H
                                DONVI_GIO DATA 47H
                                CHUC_GIO DATA 48H
                                FLAG_SET DATA 50H ;0 = KHONG SET ,1= SET GIAY, 2 = SET PHUT , 3 = SET GIO
                                LED_GIAY BIT P0.0
                                LED_C_GIAY BIT P0.1
                                LED_PHUT BIT P0.2
                                LED_C_PHUT BIT P0.3
                                LED_GIO BIT P0.4
                                LED_C_GIO BIT P0.5
                                SW_1 BIT P3.5
                                SW_2 BIT P3.6
                                SW_3 BIT P3.7
                                LED_DATA EQU P2
                                CSS BIT P3.0
                                AS BIT P3.1
                                R_W BIT P3.2
                                DSS BIT P3.3
                                NGAT_DS BIT P3.4
                                DS12887_DATA EQU P1
                                ORG 00H
                                LJMP MAIN
                                ORG 0BH
                                LJMP NGAT_TIME
                                ORG 04AH
                                MAIN:
                                MOV GIAY,#0
                                MOV PHUT,#0
                                MOV GIO,#0
                                MOV BIEN_NHAY,#0
                                MOV XUNG_NHAY,#0
                                MOV FLAG_SET,#0
                                MOV R0,#0
                                MOV IE,#10001010B
                                MOV TMOD,#11H
                                MOV TL0,#LOW(-10000)
                                MOV TH0,#HIGH(-10000)
                                SETB TR0
                                MOV A,#0FFH
                                MOV LED_DATA,A
                                MOV A,#0FFH
                                MOV P2,A
                                LCALL kd_rtc
                                LOOP_HIEN_THI:
                                MOV A,FLAG_SET
                                CJNE A,#0,NEXT
                                LCALL DOC_DH
                                NEXT:
                                LCALL HIEN_THI
                                LCALL SCAN_KEY
                                SJMP LOOP_HIEN_THI
                                kd_rtc:
                                mov a,#0ah
                                lcall wr_add
                                mov a,#20h
                                lcall W_BYTE
                                mov a,#0bh
                                lcall wr_add
                                mov a,#06h
                                lcall W_BYTE
                                ret
                                TACHSO:
                                MOV B,#10 ;de tach phan Don Vi va Hang Chuc ra, de cat rieng vao cac Bien tuong ung.
                                MOV A,PHUT
                                MOV B,#10
                                DIV AB
                                MOV CHUC_PHUT,A
                                MOV DONVI_PHUT,B
                                MOV A,GIO
                                MOV B,#10
                                DIV AB
                                MOV CHUC_GIO,A
                                MOV DONVI_GIO,B
                                RET
                                ;doc dong ho
                                DOC_DH:
                                MOV a,#00h
                                LCALL WR_ADD
                                MOV a,#0ffh
                                MOV DS12887_DATA,a ;giai phong o nho de doc gia tri
                                LCALL R_BYTE
                                MOV GIAY,a ;xuat giay ra va luu vao o nho GIAY
                                MOV a,#02h
                                LCALL WR_ADD
                                MOV a,#0ffh
                                LCALL R_BYTE
                                MOV PHUT,a ;xuat phut ra va luu vao o nho PHUT
                                MOV a,#04h
                                LCALL WR_ADD
                                MOV a,#0ffh
                                LCALL R_BYTE
                                MOV GIO,a ;xuat gio ra va luu vao o nho GIO
                                ret
                                nap:
                                MOV A,#00H; DAT GIA TRI DAU
                                LCALL WR_ADD
                                MOV A,GIAY
                                LCALL W_BYTE;00GIAY
                                nop
                                nop
                                MOV A,#02H
                                LCALL WR_ADD
                                MOV A,PHUT
                                LCALL W_BYTE;0 PHUT
                                nop
                                nop
                                MOV A,#04H
                                LCALL WR_ADD
                                MOV A,GIO
                                LCALL W_BYTE ;
                                RET
                                RET
                                WR_ADD:
                                SETB CSS; DINH DIA CHI LEN RTC
                                MOV DS12887_DATA,#0ffh
                                CLR R_W
                                CLR DSS
                                CLR AS
                                NOP
                                SETB DSS
                                SETB R_W
                                NOP
                                SETB AS
                                CLR CSS
                                MOV DS12887_DATA,A
                                CLR AS
                                ret
                                ;ghi dl
                                W_BYTE:
                                CLR R_W
                                NOP
                                MOV DS12887_DATA,A
                                SETB R_W
                                NOP
                                SETB CSS
                                SETB AS
                                ret
                                ;doc dl
                                R_BYTE:
                                CLR DSS
                                NOP
                                MOV A,DS12887_DATA
                                SETB DSS
                                SETB CSS
                                SETB AS
                                RET
                                ret
                                HIEN_THI:
                                LCALL TACHSO
                                MOV A,FLAG_SET
                                CJNE A,#0,CHOP_NHAY
                                LCALL HIENTHI
                                AJMP THOAT_HIENTHI
                                CHOP_NHAY:
                                MOV A,BIEN_NHAY
                                LCALL HIENTHI
                                AJMP THOAT_HIENTHI
                                CHOP_NHAY1:
                                LCALL NHAY
                                JMP CHOP_NHAY
                                THOAT_HIENTHI:
                                RET
                                HIENTHI:
                                LCALL HIENTHI_S
                                LCALL HIENTHI_P
                                LCALL HIENTHI_G
                                RET
                                NHAY:
                                MOV A,FLAG_SET
                                CJNE A,#1,KT1
                                LCALL HIENTHI_P
                                LCALL DL
                                LCALL HIENTHI_G
                                LCALL DL
                                KT1:
                                MOV A,FLAG_SET
                                CJNE A,#2,KT2
                                LCALL HIENTHI_S
                                LCALL DL
                                LCALL HIENTHI_G
                                LCALL DL
                                KT2:
                                MOV A,FLAG_SET
                                CJNE A,#3,THOAT_N
                                LCALL HIENTHI_S
                                LCALL DL
                                LCALL HIENTHI_P
                                LCALL DL
                                THOAT_N:
                                RET
                                HIENTHI_S:
                                MOV DPTR,#DEC_TO_7SEG ;THAM CHIEU BANG CHUYEN DOI TU THAP PHAN QUA MA LED 7 DOAN
                                MOV A,DONVI_GIAY ;hien thi hang don vi cua Giay
                                MOVC A,@A+DPTR
                                MOV LED_DATA,A
                                CLR LED_GIAY ; bat led don vi giay
                                LCALL DL
                                SETB LED_GIAY
                                MOVC A,@A+DPTR
                                MOV LED_DATA,A
                                CLR LED_C_GIAY
                                LCALL DL
                                SETB LED_C_GIAY
                                RET
                                HIENTHI_P:
                                MOVC A,@A+DPTR
                                MOV LED_DATA,A
                                CLR LED_PHUT
                                LCALL DL
                                SETB LED_PHUT
                                MOVC A,@A+DPTR
                                MOV LED_DATA,A
                                CLR LED_C_PHUT
                                LCALL DL
                                SETB LED_C_PHUT
                                RET
                                HIENTHI_G:
                                MOVC A,@A+DPTR
                                MOV LED_DATA,A
                                CLR LED_GIO
                                LCALL DL
                                SETB LED_GIO
                                MOVC A,@A+DPTR
                                MOV LED_DATA,A
                                CLR LED_C_GIO
                                LCALL DL
                                SETB LED_C_GIO
                                RET
                                NGAT_TIME:
                                INC XUNG_NHAY
                                SETB TR0
                                PUSH ACC
                                CJNE A,#25,TIME1
                                MOV XUNG_NHAY,#0
                                INC BIEN_NHAY
                                MOV A,BIEN_NHAY
                                CJNE A,#3,TIME1
                                MOV BIEN_NHAY,#0
                                TIME1:
                                POP PSW
                                POP ACC
                                RETI
                                SCAN_KEY: ;KIEM TRA PHIM NAO DUOC BAM
                                SW1: ;SET TIME
                                JB SW_1,SW2
                                INC FLAG_SET
                                MOV A,FLAG_SET
                                CJNE A,#4,L_SW1
                                MOV FLAG_SET,#0
                                LCALL nap
                                L_SW1:
                                LCALL DL1
                                LCALL DL1
                                LCALL DL1
                                LCALL DL1
                                LJMP SW1
                                SW2: ;SET_MIN
                                JB SW_2,SW3
                                MOV A,FLAG_SET
                                CJNE A,#0,SW20
                                LJMP NOKEY
                                SW20:
                                MOV A,FLAG_SET
                                CJNE A,#1,TANG_PHUT ;
                                JB SW_2,SW3
                                TANG_GIAY:
                                INC GIAY ;Roi tang Bien phut them 1
                                MOV A,GIAY
                                CJNE A,#60,T_GIAY ;
                                MOV GIAY,#0 ;Neu = 60 thì set bien nay = 0
                                T_GIAY:
                                LCALL DL1
                                LCALL DL1
                                LJMP SW2
                                TANG_PHUT:
                                MOV A,FLAG_SET
                                CJNE A,#2,TANG_GIO ;
                                JB SW_2,SW3
                                MOV A,PHUT
                                CJNE A,#60,T_PHUT ;
                                T_PHUT:
                                LCALL DL1
                                LCALL DL1
                                LJMP SW2
                                TANG_GIO: ;SET HOUR
                                MOV A,FLAG_SET
                                CJNE A,#3,SW3
                                JB SW_2,SW3
                                MOV A,GIO
                                CJNE A,#24,T_GIO ;Bien gio = 60? - Thoat khoi ngat Time0 neu khong =
                                MOV GIO,#0
                                T_GIO:
                                LCALL DL1
                                LCALL DL1
                                LJMP SW2
                                MOV A,FLAG_SET
                                CJNE A,#0,SW30
                                LJMP NOKEY
                                SW30:
                                CJNE A,#1,GIAM_PHUT ;
                                JB SW_3,NOKEY
                                GIAM_GIAY:
                                DEC GIAY ;Roi tang Bien phut them 1
                                MOV A,GIAY
                                CJNE A,#-1,G_GIAY ;Bien Phut = -1? - Thoat khoi ngat Time0 neu khong =
                                MOV GIAY,#59 ;Neu = -1 thì set bien nay = 60
                                G_GIAY:
                                LCALL DL1
                                LCALL DL1
                                LJMP SW3
                                GIAM_PHUT:
                                CJNE A,#2,GIAM_GIO ;
                                JB SW_3,NOKEY
                                MOV A,PHUT
                                CJNE A,#-1,G_PHUT ;Bien Phut = -1? - Thoat khoi ngat Time0 neu khong =
                                G_PHUT:
                                LCALL DL1
                                LCALL DL1
                                LJMP SW3
                                GIAM_GIO:
                                MOV A,FLAG_SET
                                CJNE A,#3,NOKEY
                                JB SW_3,NOKEY
                                MOV A,GIO
                                MOV GIO,#23
                                L_GIAM_GIO:
                                LCALL DL1
                                LCALL DL1
                                LJMP SW3
                                NOKEY:
                                RET
                                DL:
                                MOV R7,#200
                                DJNZ R7,$
                                RET
                                DL1: ; TAO DL DUNG CHONG RUNG CHO PHIM NHAN
                                PUSH 00H ; DONG THOI VAN CHO PHEP HIEN THI LED 7 DOAN
                                PUSH 01H
                                MOV R1,#20O
                                DL2:
                                LCALL HIEN_THI
                                LCALL HIEN_THI
                                MOV R0,#250
                                DJNZ R0,$
                                DJNZ R1,DL2
                                POP 01H
                                POP 00H
                                RET
                                DEC_TO_7SEG:
                                DB 03H,9FH,25H,0DH,99H,49H,41H,1FH,01H,09H
                                RET
                                END
                                Nguyên cái code này của bạn mình copy thành file .asm rồi biên dịch thành File .hex thì nó ra File.hex ko giống như của bạn đã up lên thế. Bạn xem lại giúp mình với, cảm ơn
                                http://www.4shared.com/file/n_M8Pnbv/1307.html
                                miehaui Tìm hiểu thêm về miehaui
